Fuel Strainer Sock Replacement
Old May 11, 2019 | 01:34 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Fuel Strainer Sock Replacement
I ran the gas in the tank way down yesterday so that I won’t be elbow deep when I change the sock. Assuming I can get my hand through the filler hole, are there any tricks for removing the old sock or attaching the new one?
I had to chuckle this morning when looking at it closely. That fuel opening looks so huge whe you’re fueling up at the pump yet so small when trying to fit your hand through it.
Old May 11, 2019 | 02:28 PM
jackson's Avatar
jackson
both twist & pull
Old May 11, 2019 | 04:48 PM
bigvette1's Avatar
bigvette1
Just a pressure fit on the steel pickup tube. Must have small hands or go get a boy no older than 10 who might be able to do it. Not bad though unscrewing the bottom.
Old May 11, 2019 | 06:06 PM
jackson's Avatar
jackson
FYI ... a full tank of race gas dissolved mine.
Old May 11, 2019 | 06:31 PM
CanadaGrant's Avatar
CanadaGrant
I tried to get my wife to do it but believe it or not, she refused. Taking out the sender from underneath is easy and you can then clean out any debris from the bottom of the tank.
Old May 11, 2019 | 10:22 PM
CA-Legal-Vette
Starting to think this is the way to go. As a bonus, my guage read 1/8 when I ran out of gas yesterday. May replace the whole unit while I’m at it.
I did talk to my wife about doing this for me. I love the idea of calling the fire department on Mother’s Day to free her stuck hand but the cost was way too high: full spa day.
Old May 11, 2019 | 11:58 PM
riverracer au's Avatar
riverracer au
on my '72, i just bent the arm slightly, reinstalled sender and checked with a measured amount of gas on level ground.
kept doing this until it read correctly, well as best as i could anyway,
Old May 13, 2019 | 03:04 PM
pltmgr's Avatar
pltmgr
I can get my hand in but can't get it out without spraying WD 40 on it
Old May 13, 2019 | 06:24 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I saw who posted this and couldn't resist posting... For me, @ 6-4 with large hands I can't get into the filler neck to replace the sock. But two things I'd do.... 1, I'd drain the fuel from the car and remove the sender. 2) I'd bench test the sender before installing a new sock. 0 is empty and 90 ohms is full. So test the sucker before you put it back in the tank.
E
To Fuel Strainer Sock Replacement
