'71 Radio Troubleshooting
Old May 12, 2019 | 04:01 PM
pwsusi's Avatar
pwsusi
Default '71 Radio Troubleshooting
Hi,
The original (mono) AC Delco radio in my '71 LT-1 recently started acting up. The radio will work for a while, then out of nowhere the volume will fade quickly to silence. If i turn the radio off and then back on again sometimes it will start playing again...or sometimes i have to leave it off for a little while for it to start working again. Based on this behaviour I'm thinking it may be the radio and/or amplifier (as opposed to the speakers) but don't know how to test these.
Any tips on how to diagnose the problem would be appreciated.
Thanks,
Paul
Old May 12, 2019 | 04:53 PM
71 Green 454's Avatar
71 Green 454
When was the last time you cleaned the potentiometer?
Old May 12, 2019 | 05:03 PM
pwsusi's Avatar
pwsusi
Never. Forgive me but i'm a novice here with these radios. How would i go about cleaning it?
Old May 12, 2019 | 09:24 PM
7T1vette's Avatar
7T1vette
With ignition OFF, give the radio volume **** several full turns CW and CCW. That will allow the potentiometer wiper to rub any dirt and/or corrosion off the windings. If that solves your problem, so be it. There is a spray cleaner than you can shoot in dirty 'pots', if needed.
If you have replaced the speakers in your car and kept the original Delco radio, there could be an impedance mis-match which could cause the amplifier section to run 'hot' (over-current condition). If this is the case, please fill in some gaps on how many speakers, how they were wired, and what their impedance is. If done properly, there will be no issue with the setup. But modern speakers have much lower impedance than the ones installed in C3's; and lower speaker impedance means higher current draw by them.
Old May 13, 2019 | 01:55 PM
blue by you's Avatar
blue by you
Had the same problem with mine, i sent it out to be repaired to a guy by the name of jerry
i think hes is on the forum, he only repairs vette radios
Old May 13, 2019 | 03:13 PM
pwsusi's Avatar
pwsusi
If you have his contact info and wouldn't mind sending it over i'd appreciate it
To '71 Radio Troubleshooting
