Rough running at highway speeds
Old May 12, 2019 | 07:56 PM
Bhebert449's Avatar
Bhebert449
Default Rough running at highway speeds
Please help diagnose what is causing my 69 427 tri power to run rough. I typically only notice after warm up and a few miles of highway driving. I can feel the engine to start to run a bit rough and it is most noticeable after I slow down and reaccelerate after cruising on the highway. Also on deceleration at high speed the exhaust is very rough sounding.
Carb has been rebuilt by Lars. I’ve replaced wires and plugs and set timing according to Lars paper at 36 degrees all in. I feel like the issues is electrical but need to know what I should consider next.
Old May 12, 2019 | 08:56 PM
mortgageguy's Avatar
mortgageguy
Distributor cap?
Old May 12, 2019 | 09:02 PM
Bhebert449's Avatar
Bhebert449
Originally Posted by mortgageguy
Distributor cap?
How do I know if it’s bad? Problem only presents at highway speeds. Seems to run fine in city driving.
Old May 13, 2019 | 12:06 AM
Puniphorous's Avatar
Puniphorous
Vacuum leak.
Old May 13, 2019 | 06:47 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Check your vacuum lines, choke (the pull off maybe bad), fuel pressure and the ignition system. I was chasing a problem all weak and some of it was due to a bad distributer.
Old May 13, 2019 | 08:21 AM
Bhebert449's Avatar
Bhebert449
Wondering why it would only happen when cruising at 3k rpms? Something in the distributor?
Old May 13, 2019 | 01:21 PM
Puniphorous
vacuum leak causing timing to be erratic?
Just a guess
Old May 13, 2019 | 01:48 PM
Rescue Rogers
Could be too much vacuum advance. Last summer my cars distributor was fine. It had two issues this spring. The upper bushing broke and was allow the plate to move that has the points on it and the stock plastic sleeve that limits the vacuum advance deteriorated so i was getting about 15* to 20* of advance if i remember correctly. I put in the brass replacement limiter then noticed the shaft bushing
Old May 13, 2019 | 06:34 PM
kanvasman's Avatar
kanvasman
I had a C2 SB and I had a similar issue, Went through all the known issues over time and could not figure it out. Out of desperation I put in a new distributor and the problem was gone. Back then I wouldn't have known exactly what the problem was, bad bearing, bent shaft, who knows but I had gone through the points, weights,the cap etc and it was the dizzy itself. Not knowing how old yours is or what kind of shape it might be in, I just thought I would throw my experience out there.
Old May 13, 2019 | 07:25 PM
mortgageguy
Remove the dist. Cap. Look for burned or worn contacts. Also carbon tracking. Anything that doesn't look normal. Check the tip of the rotor while in there.
Old May 13, 2019 | 11:02 PM
Bhebert449's Avatar
Bhebert449
So most likely a vacuum leak or something in the ignition system?
Old May 14, 2019 | 06:47 PM
Rescue Rogers
Thats the general consensus so far. Its hard to be a mechanic long distance.
Old May 14, 2019 | 09:03 PM
mortgageguy
Wouldn't a vacuum leak affect all rpm ranges and cold or hot engine?
Old May 14, 2019 | 09:58 PM
Bhebert449's Avatar
Bhebert449
Only happens when engine is warmed up and when cruising at highway speeds. 3000-3500 rpms.
Old May 14, 2019 | 09:59 PM
kossuth's Avatar
kossuth
May also be a coil. Spark might be cutting out/getting erratic if the windings in the coil are beginning to break down. Like others said kinda hard to diagnose online. Make sure it's also maintaining proper fuel pressure too and the tank sock isn't plugged up or something. These are both things that can happen from a long run condition.
Old May 14, 2019 | 10:19 PM
Bhebert449's Avatar
Bhebert449
I will replace coil next. How do I monitor fuel pressure while driving?
To Rough running at highway speeds
