Recommended distributor
Old May 14, 2019 | 07:25 PM
Black74vette's Avatar
Black74vette
5th Gear
Default Recommended distributor
New member and also new corvette owner,recently bought a 74,needs some work but going to try to bring it back to life!!! Been having some issues getting the correct distributor.all the performance shops in my area keep getting me the standard small block 350 chev distributor however I know 62-74 has the cable drive for the tach,I’m in Canada and am thinking on going with the msd tach drive pro billit any thoughts???
Old May 14, 2019 | 08:24 PM
jackson's Avatar
jackson
as cheap as $40 delivered to USA ... Tach Drive HEI ... of course they're Asian
https://www.ebay.com/itm/Chevy-V8-HE...frcectupt=true
- edit -
the above ad read tach drive but I don't see it
here's another that's under $50 delivered to USA ... no doubt also Asian
https://www.ebay.com/itm/1962-74-Cor...frcectupt=true
Old May 15, 2019 | 11:59 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The MSD is nice but you need the adjustable rotor to get it to clock correctly with the shielding. The tach drive isnt located in the same place as the GM distributor plus you'll need the 6AL contoller and HEI wires
If you want to stay with the small cap instead of the big cap HEI style, put a WTB add on our for sale section looking for a rebuilt GM tach drive.
Old May 15, 2019 | 12:02 PM
MelWff's Avatar
MelWff
why are you trying to replace the distributor as opposed to repairing it?
Old May 15, 2019 | 04:45 PM
Black74vette
5th Gear
The car didn’t come with the factory distributor,the one that’s in it does not come with the tach drive so my tach currently is not working
Old May 16, 2019 | 07:32 AM
3X2's Avatar
3X2
My personnel opinion: Get a factory T.I. distributor. Email Lars here on the forum for his papers on distributors and timing. The T.I. distributor will trigger a cheap GM 4 pin h.e.i. module.
Old May 17, 2019 | 06:59 PM
suprspooky's Avatar
suprspooky
I'm running the MSD with 6AL. The MSD Billet can be wired to work with the GM HEI Module. If you want to go that route let me know (it's a way to see if you MSD box is having issues), you'll need to make some connectors. I've run the GM points, GM TI, MSD and Mallory Unilite (all tach drive), you just need to do creative wiring.
Old May 17, 2019 | 07:06 PM
76strokervette's Avatar
76strokervette
You can order a Davis unified Ignition distributor with a mechanical tach drive.
Will give you Hei power with the tach drive in one package.
Old May 18, 2019 | 09:55 AM
derekderek's Avatar
derekderek
diff between DUI and chinese tach drive dist is 350 bucks. i am sure it is better, but 8 times as good?
Old May 18, 2019 | 02:26 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Another vote for DUI. Sure, it cost more, but you are assured a quality product vs. cheap Chinese junk.
To Recommended distributor
