Distributor Gasket?
Old May 17, 2019 | 09:36 PM
Turbotrad's Avatar
Turbotrad
Default Distributor Gasket?
It's been a while since I removed and replaced a distributor. I'm getting ready to re-install and my old distributor base gasket needs replacing. Is there any special thing to do with the replacement paper material gasket (e.g., gasket sealant), or just install it dry against cleaned up mating surfaces?
Old May 17, 2019 | 09:43 PM
ykf7b0's Avatar
ykf7b0
Dry works well for me.
Old May 17, 2019 | 10:37 PM
Mooser's Avatar
Mooser
Also, could you change your profile to include the year of your car, sometimes helps to know what it is without having to guess at the avatar
Rough location doesn't hurt either
M
Old May 17, 2019 | 11:50 PM
Turbotrad's Avatar
Turbotrad
My apologies for being on this forum for so long and not having a filled out profile. I'll fill it out and take my lashings.
Glad to have time for the hobby again 😁
CanadaGrant's Avatar
CanadaGrant
The machined finish at the round distributor mating surface on some of the old factory aluminum intakes was not great with lines and ridges around the pad so I use a very thin coat of sealer applied with my finger between the gasket and manifold and nothing between the gasket and distributor. If you tried to use sealer between both you would never be able to adjust the timing.
Old May 18, 2019 | 07:50 AM
Mooser's Avatar
Mooser
Also, if anything has changed, make sure the distributor isn't bottoming out on the oil pump for any reason. There needs to be a little up/down play on the rotor after it's clamped
M
Old May 18, 2019 | 10:14 AM
Turbotrad's Avatar
Turbotrad
Thanks for the tips! The sealer on just the intake manifold idea seems like a no brainer, but something that could easily be screwed up if not paying attention. Man would that be frustrating discovering that when it's time to adjust the distributor!
Old May 18, 2019 | 10:16 AM
Turbotrad's Avatar
Turbotrad
M
I assume that if it has not bottomed out, then the up and down movement you speak of is because of the distributor shaft end play and the value it was shimmed to, correct?
Old May 18, 2019 | 10:38 AM
Mooser's Avatar
Mooser
Yup, the end play should be whatever the gear was shimmed to. Generally speaking if you drop it in without the gasket and there is still a little up/down movement you know for sure you're good when the gasket is installed (expansion and all that)
M
Old May 19, 2019 | 11:44 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Distributor gasket? Who uses a gasket there? It would be difficult to ever know if there was a gasket there or not let alone the wrong one or a broken one.
Old May 19, 2019 | 03:41 PM
Goody's Avatar
Goody
The gasket is to help with oil seepage, corrosion between dissimilar metals (iron intake, aluminum dizzy housing) as well as the shimming because of play due to tolerances in manufacturing.
Well, that's my opinion of it anyway......
Old May 19, 2019 | 08:54 PM
HeadsU.P.'s Avatar
HeadsU.P.
Who uses a distributor gasket? H-m-m-m-m. I'm guessing everyone but you. Try it. You'll like it!
To Distributor Gasket?
