need help installing trans
Old May 20, 2019 | 07:24 PM
57russ's Avatar
57russ
Cruising
Default need help installing trans
ok first this is what i got, cant afford any other at this point lol . so i have a 72 vet with muncie 4 speed i wamt the tko but i have a 86 4+3 transmission. looks like it will replace the muncie in size . but the trans mount looks like i mite have to fabricate . any ideas on a transmission mount
Old May 20, 2019 | 09:08 PM
Bikespace's Avatar
Bikespace
Keep the 4-speed! Save your money for a real TKO 600, Richmond 5-speed, T56 6-speed, or the equivalent. There's a reason they stopped making C4s.
If your car was stock with a 4-speed, you'll likely want to consider swapping to a removable crossmember. There are kits, and folks on this forum have done it. If you have an automatic, G Force Crossmembers (and others) make bolt-in replacements for different transmissions. They may be able to help you with one that works for the 4+3.
https://www.crossmembers.com/product...body-corvette/
Old May 20, 2019 | 09:21 PM
57russ's Avatar
57russ
Cruising
well got the m20 muncie engine is going back in this week . i have both trannys and as long as i treat the overdrive good ,should last tell i can get a tko but would like to drive it so has any one ever put a 4+3 in a 72 vet im thinking i can use the same crossmember it is for a manual trans and welded in lol
Old May 20, 2019 | 10:39 PM
carriljc's Avatar
carriljc
Since you have both trannys - take a picture of them side by side. I fabricated the mount for my Richmond. Perhaps we can give some ideas when we see the trannys side by side.
Old May 20, 2019 | 11:19 PM
derekderek's Avatar
derekderek
The 4+3 is the LAST choice for an overdrive trans in a C3. Just look how far apart the C4 seats are. And how big the tunnel is. That is how big a 4+3 is.
To need help installing trans
