Power steering pump
Old May 23, 2019 | 12:00 PM
mike914's Avatar
mike914
Default Power steering pump
Hello
i will be replacing my power steering pump this weekend and hoped I would get some advicce
when I pulled to old one out it was filled with ATF fluid the red color type
should I stick with ATF as GM warns against using it and to use acdelco power steering fluid
if I Chang the fluid to ps would I have to flush the system?
mike
Old May 23, 2019 | 04:49 PM
MelWff's Avatar
MelWff
I would just buy a brand name PS fluid and drain as much as possible of the old by disconnecting the hoses and pushing the wheels back and forth.
Old May 24, 2019 | 08:42 PM
mike914's Avatar
mike914
Thanks for the advice
I disconnected and removed old pump.
Key rolled and opened up keyway on shaft and destroyed the pulley
So I bought a reman pump (not and exact fit)
New pulley 100.00 owch
Belt
Turned wheels stop to stop 20 times with car jacked up and engine off
Turned wheels 10 times with car jacked up and motor running
topped off level
Went for a spin around the block
Feels great easy to turn not overpowered
Thanks for all the advice
Mike
To Power steering pump
