Serpentine Sytem - help please
Old May 23, 2019 | 02:19 PM
Userj8670's Avatar
Userj8670
Default Serpentine Sytem - help please
Hi guys -
Looking at the serpentine system #20580 from March Performance. This is for my '72 Big Block 454. I am being told that I need a new power steering pump as my existing keyway pump will not work?
Can't anyone confirm this for me?
Old May 23, 2019 | 04:20 PM
Gunfighter13's Avatar
Gunfighter13
Originally Posted by Userj8670
Hi guys -
When you order it from March you select the pump you are using.
Old May 23, 2019 | 04:52 PM
Userj8670's Avatar
Userj8670
Correct - I called and spoke with Price, placed my order. I am now being told it will not fit with my current Saginaw pump and need to order a GM type 2 pump?
Old May 23, 2019 | 05:47 PM
Mooser's Avatar
Mooser
Just had a quick look and of the 5 setups they show for the big block corvette, only one says the GM type II pump while the other 4 say
  • Chrome Saginaw keyway canister power steering pump (reservoir included
Which version did you order? (and for that price you'd think it would come with a pump)
M
Old May 23, 2019 | 07:33 PM
Userj8670's Avatar
Userj8670
M
I ordered the short water pump one #20850. Re-reading the fine print it does mention if going on a c3, a factory pump will not work.
Well I guess I'm glad the guy called me b4 he sent it.
I can't justify an additional cost for a new power pump on top of the cost of the setup when my existing one works fine
Old May 23, 2019 | 07:37 PM
OldCarBum's Avatar
OldCarBum
Smart move.
The serpentine systems are nice but very costly and not worth the expense in my opinion.
There are some more reasonably priced options out there, but you'll still need the new water pump at the minimum.
Old May 25, 2019 | 10:44 AM
BigBill94's Avatar
BigBill94
Smart move.
My car has the March Performance C3 corvette kit, it was installed by the PO.
It's a dual belt design, and it does look cool.
It's a LOT of parts. It does not have automatic tensioners in it, you have to use an adjusting tool or a pry bar and a rag to tighten the belts.
If it was me buying a new one and that's what I wanted, I would gravitate towards Billet Specialties or similar that uses an automatic tensioner, and does not rely on the stacked belt design (uses two belts) of the March C3 kit.
This is the one on my car: https://marchperformance.com/chevy/c...ntine-kit.html
ANYWAYS... figured I'd chime in FWIW.
Old May 27, 2019 | 05:03 PM
Userj8670's Avatar
Userj8670
Thanks for the post. I am just going to use the V-belt system as it's the cheapest way to go. The customer service at March Perf left much to be desired.
Jim
Old May 30, 2019 | 12:50 PM
caskiguy's Avatar
caskiguy
Jim
You may consider this. Not sure about fit, you'd have to research it.
https://www.chevrolet.com/performanc...-drive-systems
https://www.hotrod.com/articles/chev...-c3-corvettes/
Good luck.
To Serpentine Sytem - help please
