Do I need another proportioning valve
Old May 23, 2019 | 04:04 PM
Orange 73's Avatar
Orange 73
2nd Gear
Default Do I need another proportioning valve
I have a 73 and am replacing the master cylinder with a wilwood master. Can I just install it with the OE proportioning valve or do I need to get a new tandem adjustable proportioning valve? Thanks
Old May 24, 2019 | 06:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You're original is a pressure differential switch and not a proportioning valve. The aftermarket unit you mention sounds like an actual proportioning valve. Which do you want?
Old May 24, 2019 | 10:37 AM
bazza77's Avatar
bazza77
Doesn't the Elwood unit come with adapters so you can just plug in your existing hardlines ?
It's just an expensive light weight thing that does the same as an oem unit.
If your going serious track racing with a large fuel tank you might use a manual bias control , if not then the factory set up will still be good for what most people would want.
Just my opinion
Old May 24, 2019 | 12:06 PM
OldCarBum's Avatar
OldCarBum
Call Wilwood and ask their service techs.
When I purchased my Wilwood brakes they told me there was no need to change to a proportioning valve unless I was track racing my car with serious chassis and suspension modifications.
Old May 24, 2019 | 12:37 PM
GTR1999's Avatar
GTR1999
This is correct. It is only there to tell if pressure is lost in the front or rear system, then a spool is shifted and makes the switch to light the dash brake light.
Most seem to think this a pressure adjusting switch to bias pressure between the front and rear calipers. Then again some think you can tighten the lash screw on the steering box and back it off 1/4 turn and it is adjusted.
Old May 24, 2019 | 07:47 PM
HeadsU.P.'s Avatar
HeadsU.P.
The proportioning valve does a little more than just trigger a switch & warning light. It has a metering valve in the front of the unit and a pressure spring in the rear. In the event that either the front or rear brake system fails, loss of pressure, I believe the spool or piston is to shut off the faulty brake line so as to have the capability to still have pressure in half the system. Or a proportion of the brake fluid is blocked off until repairs can be made.
I have a diagram of the internal workings of the prop valve in my profile photo album.
The prop valve can not bias the amount of pressure going to the rear such as those needed on a disc / drum setup. That would be an adjustable type, often having a **** on the unit to tweak the braking system.
Old May 25, 2019 | 08:54 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
But a '73 doesn't have a proportioning valve as already mentioned. No need to confuse the OP.
Old May 26, 2019 | 09:43 AM
HeadsU.P.'s Avatar
HeadsU.P.
Really? H-m-m-m-m-m-
Ecklers. P/N # 25-162823-1 Proportioning Valve, fits 1970- 1973, $124.88
Old May 26, 2019 | 09:54 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
The car left the factory with a pressure differential switch as noted in this thread.
Old May 27, 2019 | 11:03 AM
OldCarBum's Avatar
OldCarBum
Correct
Old May 27, 2019 | 12:21 PM
GTR1999's Avatar
GTR1999
Not to start an argument with anyone or anyplace, but that Eckler part is a not a proportioning valve. It is a remake of the original pressure diff switch. The pin contact is in the center of the spool in the switch. If the spools shifts from pressure loss, it makes contact and powers up the red dash brake lamp. This just reflects the way parts are sold today compared to years ago.
Old May 27, 2019 | 07:19 PM
HeadsU.P.'s Avatar
HeadsU.P.
Then I suggest we form a posse and ride on up to the vendor and conduct a lynching. And any other vendors that falsely label parts. We will meet at noon.
Anybody know how to tie a noose?
Old May 27, 2019 | 08:11 PM
GTR1999's Avatar
GTR1999
Yes I know how to tie a 13 loop hangmans noose but I would rather work on differentials, arms, and boxes.
To Do I need another proportioning valve
