What puzzles me is that the capacitor seems to be on the ground side; there is a black wire with male spade on one side and the other is grounded to the clock’s back plate. I always thought the things went on power side, that current had to go through it to activate the device.
"The clock capacitor. I think its bolted to the correct spot but the brass end on the black wire will slide inside the power wire when you put it on the clock spade. The cap should stop the clicking when the clock rewinds when on AM radio."
This seems to make the most sense to me.
How do you like that radio? I just got the same for mine. The volume **** is a bit sensitive to me, but you can't beat the look.
I haven't really put mine to work yet.
So far overall I do like it... but, indeed, the volume **** is a bit sensitive. the fade and tone ***** seem a little wobbly. I tried to fix the backing with felt. I was mildly successful.
