Need some timing help-way off the mark
What if ... what if your "HEI wire retainer" somehow was replaced by someone and they got it wrong ... what if they used one from mid-70's Cadillac V8?? ... looks & fits like any other ... except those have a Very different firing order.
I went back to square one as some have suggested. Pulled out #1 plug, stuck my finger in the hole and bumped the starter until I knew I was on compression stroke. When it got to TDC on the dampener, the rotor was pointing at #8 position. Don't know how that happened!! I also pulled the rocker cover after this photo to confirm the 2 rockers were in the closed position. I guess while I have the rocker cover off, I'll recheck all the lash. Will get things back to where they should be in the next couple days and we'll see if it runs better. I will report back.
Drop me en e-mail for my HEI installation paper for correct position and installation of the HEI distributor.
Lars
V8FastCars@msn.com
But I still think something is not right because the vacuum is so low (13-14")
If the damper is set to 0 * mark, the dissy is pointing to the NEW #1 plug wire spot on the cap, not the ring wire numbers. . That is your number 1 wire location.
If you want a different #1 plug wire spot on the cap , pull the dissy and turn it counter clockwise 1 or 2 wire spots and drop it back in. (you may have to turn the oil pump with a long screw driver to get the dissy to drop in to the pump slot)
Back in the day I marked the dissy base for factory #1 wire and dropped it in to align with my #1 mark.
Today, since I don't care where #1 wire is I drop in the dissy and get it close to pointing to the #1 spark plug and just wire the cap starting to where the dissy is pointing to the new #1 on the cap. I don't care about the ring #.
Rebuilt dizzy
Before rebuild
If the springs for the weights are too stiff you will not get mechanical advance, don't know what setup you have.
One question - do you have 12 volts going to the dissy or are you still running a resistance in the feed line?
To get my dist to be "all-in" mechanically at 3000 rpm, I used 1 weak and 1 medium spring from a kit, and I used the stock weights (ZZ4 take off dist). It looks like you have the new, and perhaps lighter, weights from the kit, along with the heaviest springs. You might see advance at redline, but not at low RPM.
Edit: center plate appears to be installed correctly.
Regarding the timing mark, I'd either check the timing mark with a piston stop or pull the crank pulley and see if the timing mark has slipped, there should be an index mark on the balancer hub that lines up with the timing mark.
seems you borrowed another timing light and verified timing light is Not a culprit.
Suggest you buy, beg or make a cheap spark plug-hole piston stop TDC locator.
gently roll motor clockwise 'till it stops; make an "A" mark on damper where tab indicates "ZERO"
repeat but counter-clockwise; mark damper "B"
Damper's factory groove-mark should be at virtual middle of shortest distance between A & B ... if it IS, damper's golden ... But ...
... if Not, damper's screwed or tab's in wrong location or both.
FWIW ... you probably Know, but if not ...
... for each one Full-turn the crank makes, the Cam makes a Half-turn AND the Dist makes a Half-turn.
