So the front passenger side caliper on my 78 started leaking. Last weekend when I was determining if the caliper cylinders were sleeved I could not get the brake hose detached from the brake line, and I was out of time but wanted to get my order in for new calipers or an oring kit as there were some sales at ecklers. So I cut the brake hose so I could get the caliper off for inspection, and I idiotically didn't clamp off the hose so the fluid drained out of that line. I looked this morning and there was still about a 1/4" of fluid in the master cylinder so I did add some just to keep it from running totally dry.
Anyway, how much of an issue have I caused myself? I'd like to flush all the old fluid out of the system anyway, but obviously there's probably quite a bit of air in the lines now.
It did not, but what if it had? What's the big issue there?
If it had, you might have had to unbolt the MC and prime it. As it is, it should have no impact as you have to bleed the brakes when replacing the caliper anyways.
You might want to either crimp or fold over the cut brake line to reduce fluid loss while waiting for the parts. Also, put some PB Blaster on the brake line connection.
Get the replacement caliper in place connect a clear tube from the caliper bleeders back into the MC, pump until you get fluid with no air bubbles in the line.
Once the MC is again free of air press the brake pads in forcing the caliper pistons into the caliper bore. Shim / clamp in place and pressure bleed with 20-25 PSI at the MC.
Then do a complete brake fluid flush on the other calipers. To reduce the amount of fluid required start with the longest brake lines to the shortest brake line.
