New ignition switch, How difficult?
Can I replace the switch myself with basic tools and a beginners mechanical knowledge? :confused:
So from what you have described, your lock cylinder is what needs to be replaced. The switch down under the dash is probably OK. There are only two special tools that are required to disassembly your steering column head and replace the lock cylinder. You will need a steering wheel hub puller and also it is most helpful to have a special bridge tool to compress the locking plate after the steering wheel is removed. I think you can borrow these special tools from Autozone or NAPA retail stores.
If you go to http://www.corvettefaq.com and look under steering. Depending on whether or not you have a standard (non adjustable) steering column or a T&T there are several papers at that websight that will take you step by step in replacing your lock cylinder.
The T&T papers that you should download are entitled:
Tilt & Telescoping Column 69-82 Disassembly & Repair Paper #1
Tilt & Telescoping Column 69-82 Disassembly & Repair Pic #1
Tilt & Telescoping 76 Steering Wheel and Horn Parts
If you have a standard column here are the papers at that sight to download:
Standard column Disassembly Instructions
Standard Column Disassebmly Pics #1
Steering Wheel and Horn Parts 1976-79 Std Column Pic #4
These papers will take you right through the process of replacing the lock cylinder step by step. I'm sure you can do it.
