68 Corvette door hinges
Old Jun 2, 2019 | 07:54 PM
TJ429's Avatar
TJ429
Default 68 Corvette door hinges
All four door of my door hinges are a bit loose and wobbly.
Is it better to replace them, or purchase the refurb bushing kits I’ve seen for them and rebuild?
If the consensus is to replace, is there any place to pick up newly manufactured door hinges?
Thanks much.
Ted
Old Jun 2, 2019 | 09:37 PM
standardbyke22's Avatar
standardbyke22
when i did my 69 2 of them were cracked so i bought rebuilt ones off ebay. last month i did my 68s, it was very easy and fun, i soaked all 4 in vineager for 2 days, pressure washed, then sand blasted, the vineager cuts the time down at the booth by removing some paint and all rust., then i replaced the springs, bushings and pins, i got the kit from ecklers or zip. so as long as yours arent cracked or bent, id say go for the rebuild the kit was about 15$ and springs were around the same i think. i used a hammer to remove pins, punch to remove bushings, then just tap new bushings in, grease pin and pound it home. to reinstall spring you need a special tool- bent screw driver.
Old Jul 11, 2019 | 02:34 PM
TJ429's Avatar
TJ429
I ended up finding some on eBay that looked better than mine. If they end up needing it, I'll go with the rebuild kits from Ecklers or Zip.
Thanks much.
Old Jul 11, 2019 | 08:31 PM
Bills17n72's Avatar
Bills17n72
well if you want I have a set you can have for $50 plus shipping ,they are all the same 68 to 82
To 68 Corvette door hinges
