Capt Lee's Spra' Strip
Old Nov 6, 2002 | 04:12 PM
GTR1999's Avatar
GTR1999
Default Capt Lee's Spra' Strip
Anyone know of a web site or direct number? I did a web search and found a MSDS on it but the information line was no good? Is this still being produced?
Thanks,
Gary
Old Nov 6, 2002 | 04:16 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Capt Lee's Spra' Strip (gtr1999)
I think I saw if in an Eckler's or Mid American catalog a couple of years ago, but nothing since then. I've heard that it isn't as good as some of the other strippers available at a lower price.
Old Nov 6, 2002 | 04:39 PM
Fevre's Avatar
Fevre
Thanks,
Gary
Funny, I just got out of training class an hour ago and we went over the Material Safety and Data Sheet info. :)
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Capt Lee's Spra' Strip (Smokehouse69)
yes they still sell it theyhave it our local autosupllier here,but have you tried the razor blade method first?Less mess and faster.
Old Nov 6, 2002 | 04:50 PM
Robd's Avatar
Robd
Ecklers at http://www.ecklers.com/product.asp?p...N0SM2EPT2U80E0
Old Nov 6, 2002 | 04:53 PM
GTR1999's Avatar
GTR1999
Default Re: Capt Lee's Spra' Strip (patsnitrovette)
Hey Pat,
I did try the razor blades and heat gun. Sometimes the paint came off smooth other times it didn't and I did gouge - :eek: :eek: :eek: some spots. I was able to remove the paint down to the grey filler? or is this the gel coat? there is a red primer coat under the grey? I didn't dig into the 'glass but was wondering if the Spra' strip would leave a smoother finish?
Thanks,
Gary
Old Nov 6, 2002 | 04:55 PM
GTR1999's Avatar
GTR1999
Default Re: Capt Lee's Spra' Strip (Fevre)
Glad to hear that companies are training people in HAZCOM. I do the OHSA training here and bring everyone through once a year as a refresher.
Gary
Old Nov 6, 2002 | 04:59 PM
sb69coupe's Avatar
sb69coupe
Hey Gary, the gray coat is primer. The red coat underneath is the red oxide primer. It's the last layer of primer before you reach the bare fiberglass. Once you get to the red oxide layer, stop stripping and you'll be fine.
Shannon
Old Nov 6, 2002 | 05:36 PM
a454corvette's Avatar
a454corvette
Hey Pat,
Thanks,
Gary
There's no gelcoat on a vette as produced. Time to get friendly with the sanding block;)
Old Nov 6, 2002 | 06:00 PM
GTR1999's Avatar
GTR1999
Default Re: Capt Lee's Spra' Strip (a454corvette)
OK sounds good guys. I barely hit the red in some spots-most of it is grey. I was planning on leavingthe grey primer on and sanding filling it? Should I take it down to the red?
Thanks,
Gary
Old Nov 6, 2002 | 06:03 PM
GDaina's Avatar
GDaina
Get Bix, in the black and white can, works fast, and can be purchased at any of the building and hardware stores
Old Nov 6, 2002 | 06:15 PM
GTR1999's Avatar
GTR1999
Default Re: Capt Lee's Spra' Strip (GDaina)
Thanks George, I remember you suggesting that.
The razor blade clean up wasn't bad at all- just swept up the dry chips. I'm sure the chemical would be a bit more messy.
Gary
Old Nov 6, 2002 | 06:55 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
if you've never used chemical stripper you have no idea what a mess it is:U It does a half way job of stripping, it is still possible to mess up the fiberglass and it's toxic nasty crap that you have to clean up and avoid touching. I hate chemical strippers.
Gary
Old Nov 6, 2002 | 07:17 PM
1980ZZ4's Avatar
1980ZZ4
I've also heard that the chemical stripper is quite a mess and risky at best. The shops I'm currently talking with about doing my stripping and body work says they refuse to use chemicals on the car. They suggest dry sanding it all the way down with a DA. Just my 2 cents. Good Luck.
Brad
Old Nov 6, 2002 | 07:49 PM
GDaina's Avatar
GDaina
Default Re: Capt Lee's Spra' Strip (1980ZZ4)
I haven't a clue what the bad rap is with chemical strippers...sure it's a mess, no way around that, but it get's the paint off without any nicks and gouges. You can't prove by me it's bad stuff, not when u look at the finished product....
Old Nov 7, 2002 | 01:34 AM
a454corvette
I'd have to agree. Stripped mine with spra-strip, no problems. Of course, it was done in a commercial setting. Might be a little much for a home garage.
I'd sure hate to see a car stripped completely with a DA, the seam work that had been done in '74 on mine was bad enough.
Old Nov 7, 2002 | 02:28 AM
paintdaddy's Avatar
paintdaddy
I have used the spra strip before and ill say dont buy it from anyone but the main supplier.I bought some frome MAD and it was like jelly ,their excuse was that they buy it in bulk once a year and I had recieved the last of that shipment.DONT do the razor blade thing ,I tried that once and Ill never make that mistake again.If youll notice ,the razor blade is straight and your car is curvy .Sorry if I sound like a smart azz. :seeya :D
To Capt Lee's Spra' Strip
Old Nov 7, 2002 | 09:00 AM
GTR1999's Avatar
GTR1999
Default Re: Capt Lee's Spra' Strip (paintdaddy)
I would like to try it on a hood I have off another car. Do you have contact info for the company? I tried searching the net but couldn't find them and their phone number off the MSDS was no good?
Gary
Old Nov 7, 2002 | 11:52 AM
a454corvette
Call your local paint/body/equipment (PBE) supplier. If you don't know who to call, ask a local body shop.
Old Nov 8, 2002 | 12:07 AM
paintdaddy's Avatar
paintdaddy
I cant remember the name of the place but capt sold it to the same place that sells the battery tender,I think its called Halon Marketing. :seeya
