Paging MountainMotor
See pictures here:http://forums.corvetteforum.com/zerothread?id=427798
The guy at Corvettes and Classics, who built the engine, was drooling over the Pro Torker heads. So far, I have racked up about 75 miles on the rebuild, and it runs great. Also, the engine has a much deeper tone at idle than the old engine.
Now, if I can just restrain myself for a few hundred more miles:D Can't wait to take it to the track.
Thanks again for all your help on this project; it's much appreciated! :yesnod: :cheers:
If anyone else is interested in these Pro heads, check out this link:
http://www.procylinderheads.com/pricesproductlist.asp
OR
http://www.sdpc2000.com/cart.asp?action=catalog_start&catid=786
These heads are a great value. I have the 67cc Torker series, which is a good street head. They have other versions, like the lightning series. They are good quality heads that flow nearly as well as AFR's of the same size, but for less $$. :cheers:
[Modified by shotgun_000, 6:23 PM 11/6/2002]
How does it idle and respond with the Q-jet on it?
When you put headers on it will really come around in the middle and top if the carb is tuned for it.
Take care.
It idles very smooth, with kind of a deep growl. In fact, it idles better than the older engine. The old engine didn't idle well below 900, this one idles well down to 600 rpm.
I don't know about throttle response yet. I have really been easy with it, and haven't floored it yet. I can't wait.
When I buy roller rockers, is there anything I need to know, or will any of the quality brands work?
Thanks :seeya
