help. running rough
Old Jun 7, 2019 | 10:26 PM
surveyguyor's Avatar
surveyguyor
4th Gear
Default help. running rough
Hello, I have a 1982 CE. Stock. It is running very poorly. not much speed. i drove for 6 hours and had terrible fuel economy. It chugs along like half the cylinders are firing. I thought it was the catalytic converter but now I am not convinced. I thought I'd change out the plugs and rule those out. while I was starting to change plugs I noticed a sensor on the right rear of the block above the rear two plugs and it has 2 terminals but one was not on. What sensor is this? Where else should I be looking for problems on this crossfire injected engine? While driving on the recent trip i changed the cap and rotor thinking they could have been the problem. No change. Thanks for a starting point and thanks for letting me know if that sensor could be giving me the symptoms I am having. I did adjust the TV cable twice on the trip and it did not help.
EDIT: also, while driving, as I try to accelerator, the problem is exacerbated. It just "chugs" louder and harder. feels and sounds like a locomotive. chug-chug-chug
Old Jun 7, 2019 | 11:19 PM
terry82's Avatar
terry82
there are two sensors on the passenger side of the motor.the one by the spark plugs is the sensor for you electric fan. the lower one is a knock sensor.i would check the plugs. if they are black ,they are burning rich.i would look at the coolant sensor at the front of the motor by the water pump.If all is good there I would take a look at the throttle postion switch..
Old Jun 7, 2019 | 11:22 PM
surveyguyor
4th Gear
thanks Terry. I never knew how to pull codes until now. I just got a code 13. so maybe it's the O2 sensor ? Thanks !!!
Old Jun 7, 2019 | 11:27 PM
terry82's Avatar
terry82
how many miles on the car.those old cat coverters did plug up easy .
Old Jun 7, 2019 | 11:32 PM
surveyguyor
4th Gear
ya. i'm worried about that now since the O2 sensor could've been bad for some time making the cat plug up. The car has I think 150k off the top of my head.
Old Jun 8, 2019 | 07:57 PM
TimAT's Avatar
TimAT
Code 12 is <No Distributor Reference> Code 13 is <O2 Sensor or Circuit>
I would suggest that you get the FACTORY service manual for 1982. It has everything you'll need to keep that crossfire going. Don't waste your time with the chilton's or Haynes.
Old Jun 8, 2019 | 09:54 PM
CanadaGrant's Avatar
CanadaGrant
It's also possible the sensor was disconnected to mask or "remedy" the old cat fault.
Old Jun 9, 2019 | 12:47 AM
surveyguyor
4th Gear
thanks gentlemen, I'll look for the proper book. I think I already have the other two. Not sure if I have the factory one. I am currently away from home (next state). I appreciate the help. Changing the O2 sensor it runs a little better, but now i really notice the cutting-in and cutting-out of all the cylinders firing. I wonder if the TPS could be making it run erratic also. I'll pull codes again tomorrow
To help. running rough
