Internal engine paint
Old Nov 6, 2002 | 09:29 PM
Guest
Guest
Posts: n/a
Default Internal engine paint
Have any of you used GE glyptal paint for painting the inside of your engines, or used any other paints for painting the inside? Have you ever epoxyed screen over the oil drain holes in the lifter valley area of your engine? Did you use stainless steel screen, and if so where did you find stainless steel screen? Thank you for any advice you can give me in these areas of my engine rebuild. Tom
Old Nov 6, 2002 | 10:00 PM
dually4wd's Avatar
dually4wd
Default Re: Internal engine paint (T-Top Tom 1)
I think more important than painting the inside of the block is a thorough cleaning and deburring of any flash that could later crack loose and migrate around. The screens are mostly used with roller lifters and race engines, but you can buy kits to do it from Summit, Jegs, etc.
Old Nov 6, 2002 | 10:51 PM
Tahos's Avatar
Tahos
GE Glyptal paint is the paint to use,but I never have used it as it is not easy to find around this area. I believe GE used that paint for painting
transformers.As for the screen,I would be concerned that it would cause
a problem rather than prevent one.
Old Nov 6, 2002 | 10:59 PM
Russ Bellinis's Avatar
Russ Bellinis
Default Re: Internal engine paint (Tahos)
Glyptal paint is used to seal and protect electrical connections from water and corrosion. I would check out a Graingers, or any industrial electrical supply warehouse.
Old Nov 6, 2002 | 11:13 PM
Ken73's Avatar
Ken73
Cruise-In III Veteran
I did my valley with Glyptal. Eastwood sells it by the quart can or in a spray can.
Old Nov 7, 2002 | 05:15 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Internal engine paint (Ken73)
Yes, it dries fast too! I plan to use the screen kit from Moroso.
Old Nov 7, 2002 | 07:32 AM
MARKUS_P's Avatar
MARKUS_P
Default Re: Internal engine paint (1970 Stingray)
Just wanted to tell you that your engine looks great.
The day will come when I get into building my own engine.
Keep on good work, I feel the addiction to more power - and the influence of BB :cool:
Old Nov 7, 2002 | 07:41 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Internal engine paint (dually4wd)
The reason for the glyptal is a smoother finish for faster draining and to seal the porous casting. Dirt will embed in the pores, with glyptal on it that can't happen.
You can go all crazy with that stuff, some only do the valley, stingray did the front face of the block too. Some also do the non machined parts of the underside of the bloc.
Marck
Old Nov 7, 2002 | 05:24 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: Internal engine paint (MARKUS_P)
Thanks Markus. I got the fever too! :lol:
Old Nov 7, 2002 | 05:41 PM
jackson's Avatar
jackson
Tahos:
Glyptal/glytol ...can't remember which. Anyway, may not be too hard to find. Look in your phone book's White, Business pages under "GE Supply" ... even my little burg of about 35K has a GE Supply outlet ... & they keep it in can & aerosol.
Old Nov 7, 2002 | 05:45 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Internal engine paint (jackson)
It's glyptal and I ordered it through Eastwood.
$24.99 for 1 quart in a can, same for 12.75Oz aerosol.
Marck
To Internal engine paint
