Weird Electrical Mystery- 69BB ???
Old Nov 6, 2002 | 10:36 PM
jyounane's Avatar
jyounane
Default Weird Electrical Mystery- 69BB ???
Any help appreciated. When the ignition key is pushed all the way in into the ignition switch in the ACCESSORY, LOCK or OFF position, the relay on the left-hand fender buzzes. This is the relay on the fender, to the rear of the alternator, probably horn or headlight relay.....any thoughts???
Thanks in advance,
Joe
Old Nov 6, 2002 | 10:41 PM
sb69coupe's Avatar
sb69coupe
Default Re: Weird Electrical Mystery- 69BB ??? (jyounane)
That is the horn relay. Sounds like what you're hearing is the key warning buzzer. It's likely that your door ajar switch is faulty, causing the buzzer to sound. The wiring is on the switch in the front of the door jamb. Use a deep 7/16" (I think) socket to remove the switch and examine the wiring. You may need to remove the drivers (left) side kick panel to access the back side of the switch area if the wire has come off the switch.
Old Nov 6, 2002 | 10:46 PM
jyounane's Avatar
jyounane
Default Re: Weird Electrical Mystery- 69BB ??? (sb69coupe)
sb69coupe
That's interesting, I did have the doors open at the time. Does the horn relay act as a buzzer? The sound seemed to be coming from right there.
There's nothing in the owner's manual about a key warning device.....where can I find out more?
I really appreciate your quick response!, This forum is incredibly valuable.
Best regards,
Joe
To Weird Electrical Mystery- 69BB ???
