1st Time using timing light
Old Jun 19, 2019 | 10:57 AM
mike914's Avatar
mike914
Hello Bikespace
Yes Emailed Lars and he promptly sent the paper.
Skimmed through it and ordered the recommended spring kit to help with curve.
I have yet to buy a timing light with advance will do it this week
I will try again this weekend
Thanks for all of the help
Mike
Old Jun 19, 2019 | 11:16 AM
Bikespace's Avatar
Bikespace
Originally Posted by mike914
Hello Bikespace
Mike
Awesome! You are 80% of the way there. I'm quite happy with my Innova 5568, but there are plenty of timing light options. Let us know how it works out, and take some pictures.
Old Jun 19, 2019 | 11:35 AM
VERYSOON's Avatar
VERYSOON
+1 on the Innova 5568
Also, you can use it to set the dwell should you replace your current distributor with a points distributor. I bet Lars will POINT you in that direction!!
VS
Old Jun 23, 2019 | 08:45 AM
mike914's Avatar
mike914
Default Update
Hello Everyone
Thought I would post an update and ask for opinions.
I reached out to Lars and got his paper on setting timing.(Thanks Lars)
Also I borrowed a timing light with advance on it.
Initial dwell was only 18 on my old Sears meter.
Looked up gap on mallory site and spec for this dual point distributor is .022.
Reset to .022 and could not get car to start.
Backed it down to .020 and dwell is now 28 (best I could manage after 8 tries.)
So now I can start car but it is harder to start but runs fine.
Took it for a spin and runs well.
So according to Lars paper the next step is to remove one heavy spring.
This is where my question begins:
Wondering what I need to do to access the springs.
Does anyone have an idea?
Thanks for any advice
Mike
Pic:
Old Jun 23, 2019 | 10:14 AM
stingr69's Avatar
stingr69
Oh man....thats gotta come out. 😲
Old Jun 23, 2019 | 05:12 PM
Bikespace's Avatar
Bikespace
I'm so confused. What even is that? Do you have two sets of points, like a redundant dual ignition from an airplane? (though one appears to be disabled with felt)
Anyway, the springs should be attached to the advance weights above all of that. Was there anything between what you show and the rotor?
If you don't care about originality, consider upgrading to an HEI ignition.
Old Jun 23, 2019 | 06:59 PM
derekderek's Avatar
derekderek
That is an old dual point racing distributor with no vacuum advance. Useless. Replace it with the correct points distributor or replace it with a 74 tack drive HEI. Like this. https://www.ebay.com/itm/CORVETTE-TA...-/200941757896 edit. i don't even think it has centrif advance. i think that is a locked-out distributor.
Old Jun 23, 2019 | 10:09 PM
mike914's Avatar
mike914
Hello Bikespace
Thanks for the comment
I removed the distributor cap
Under that was the rotor
Under the rotor was the points you see in pic.
I believe the springs are under the points.
The mallory instructions P could find illustrate the opposite like you were asking.
See below
Old Jun 23, 2019 | 10:21 PM
Bikespace's Avatar
Bikespace
Hello Bikespace
See below
Exactly. I was expecting to see something like you show in Figure 2 of the Mallory instructions. As @derekderek suggested, you'd be miles ahead with a stock distributor, or an HEI with a mechanical tach drive (assuming you need that, your tach may have been converted to electric, for all we know, do you have a mechanical drive on what you have?). I don't think you'll find any springs under those points, as I doubt that distributor has the capability for mechanical advance.
Anyway, Figure 2 shows a pair of springs on the advance weights, which is what @lars is describing in his instructions, or in the instructions for the distributor spring/recurve kit you have.
My 79's distributor was shot (though correct). I bought a new one off eBay, and followed the rest of Lars' instructions, and got that car squared away and performing MUCH better for about $300-, including new plugs, wires, and timing light.
Old Jun 23, 2019 | 10:35 PM
mike914's Avatar
mike914
Hello Derekderek
Thanks for the link
Very attractive price on this unit
Any idea to a link to convert points with separate coil to HEI?
Old Jun 24, 2019 | 10:09 PM
mike914's Avatar
mike914
Hello Everyone
I believe I am making progress on this one.
I was able to get to the springs and installed the gold springs Lars recommends in his paper.
This improved starting
Dwell angle is now 30
Idle is 750 smooth
I had to return the timing light with advance as I was struggling with points .
I did hook up my cheap light and this is what I saw.
Does this mean I have some advance?
The next step to borrow the light back and set it to 36 while rotating distributor and revving engine?
Should I adjust to the 0 mark on the timing tab?
Lars states:
Set the light to 36 degrees advance.
Now rev the engine while observing the timing marks with the light.
You will notice that the stock line on the balancer will move up towards the
timing plate as rpm increases.
Continue to increase rpm until the line does not move any further (centrifugal advance is “pegged out”).
Once the timing is “pegged out,” the line on the balancer should line
up with the “0” mark on the timing tab.
Old Jun 25, 2019 | 08:20 PM
mike914's Avatar
mike914
Hello All
I figured it out
Set initial timing at idle at 12
then increased rpm to 2500 to 2900
total timing 36 degrees
Mark on balancer is lined up with the zero mark on the timing plate.
Runs strong starts well.
Still have to take it for a long ride as it started to rain just as I finished up.
Ran great through my neighborhood.
Thanks for all the advice
Mike
Old Jun 25, 2019 | 10:19 PM
  #33
Bikespace's Avatar
Bikespace
Thanks for the update! It looks like you have it sorted out pretty well. I'm happy to be proven wrong, and you were able to find a working advance mechanism under the dual points.
Enjoy the drive!
Old Jun 26, 2019 | 12:13 AM
  #34
derekderek's Avatar
derekderek
the thing you will miss with no vacuum advance is fuel economy at cruise. but if priority right now is feeling the seat push on your shoulder blades, deal with it later. did you take the felt out from second set of points and get both sparking?
Old Jun 26, 2019 | 06:54 AM
  #35
mike914's Avatar
mike914
Thanks Guys
I did not remember to remove the felt.
I will do it tonight and report back.
BTW the timing light with built in advance is well worth it.
I will be buying one soon.
Yes this car does drink gas, but the feeling when it accelerates is well worth it.
Mike
Old Jun 26, 2019 | 07:43 AM
  #36
Bikespace's Avatar
Bikespace
With a vacuum advance, you'd get that same feeling, and better off-throttle fuel economy. But you'd likely need a new distributor for that.
Old Jun 26, 2019 | 08:42 AM
  #37
derekderek's Avatar
derekderek
you do need a correct distributor. that was for the drag strip before electronic ignition existed. it is not original. just old.
