82 xfire needz
Old Jun 22, 2019 | 08:01 PM
capnron3's Avatar
capnron3
Default 82 xfire needz
if I put a performance cam and possibly the renegade intake in my 82 xfire that has dougs headers and sidepipes will it be worth it powerwise
Old Jun 22, 2019 | 09:21 PM
Fast81's Avatar
Fast81
An engine is just an air pump -- you've taken moderate care of the exhale, now its time for the inhale.
The Renegade intake will finally match up to let your factory heads use their full port potential.
Keep the cam intake @05 under 212 and the duration 112-114 so the ECM stays happy.....................and you'll be happy.
Oh, have you replaced/upgraded your fuel pump ?
All this assumes you have no vacuum leaks and your tune is good.
Member "bucaneer" is the authority of pushing the XFire to its limits
Old Jun 22, 2019 | 09:23 PM
capnron3's Avatar
capnron3
thanks an know have not upgraded fuel pump
Old Jun 22, 2019 | 10:43 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Define power? What are you looking to realistically get out of the motor or to the rear wheels with a stock ECM? There are improvements you can make, but with a stock ECM you are limited to the mods that can be done, but it will still run pretty good actually.
To 82 xfire needz
