72 4-Speed Tailshaft Housing Bushing MISSING
Old Jun 25, 2019 | 09:50 AM
Triumph74tr6's Avatar
Triumph74tr6
Default 72 4-Speed Tailshaft Housing Bushing MISSING
PROBLEM: Last night I was replacing the tailshaft bushing in my '72 350/4-speed. When I got the seal out and could see in, I couldn't see any bushing. I put the bushing removal tool in, and couldn't get ahold of anything. So then I tried fitting the new bushing in place.......and it was LOOSE. Apparently the bushing wore completely away and has worn the case away just a bit. I really do not want to take the trans out as my car has the "fixed" crossmember. Any ideas? I just spoke with my machinist about knurling the OD of the bushing. I think that might take up the clearance enough that it will get me by until I convert to 5-speed in a couple years.
Old Jun 25, 2019 | 01:06 PM
derekderek's Avatar
derekderek
you are most likely gonna need a tail housing. you could try loctite on the bushing to see if it stays. an oversize bushing and necessary machine work will be more than a housing. and not a numbers-matching piece. on ebay a bunch of t10 housings but theumy are all 58 to 64. m20-21 housings about 120 bucks. You need to do some homework on which transmission you have.
Old Jun 25, 2019 | 05:20 PM
Triumph74tr6
I have a 32 Spline M-21.
Old Jun 25, 2019 | 06:25 PM
jackson's Avatar
jackson
OP
Perhaps the old bushing is there but has migrated far forward.
Can you remove the tailhousing from the car?
Old Jun 25, 2019 | 07:01 PM
Triumph74tr6
I've read on quite a few threads on here that removing the tailhousing with the trans in place is impossible......and I believe it looking at what's in the way. I don't see any evidence of the old bushing at all. I'll get a brighter light and have another look tonight.
Old Jun 27, 2019 | 06:12 PM
Triumph74tr6
In talking with and old-time mechanic.....he advised using a product from Locktite - 660. It is made for filling gaps like I have. Up to .020" on the diameter. It's good up to 300F. I have the bushing at a machine shop having the OD knurled. I think between the two I can patch it back together to last me until the 5-speed conversion is in the budget.
Old Jun 27, 2019 | 08:18 PM
jackson's Avatar
jackson
if the gap's OK, that 660 looks promising.
Old Jun 28, 2019 | 05:42 PM
derekderek's Avatar
derekderek
ok if only 20 oversize it can only be so far off center. like .010
To 72 4-Speed Tailshaft Housing Bushing MISSING
