AC Solenoid
Old Jun 26, 2019 | 09:55 AM
Jason 1979's Avatar
Jason 1979
Default AC Solenoid
I have a 79 auto with air. The AC solenoid that holds the rpms up a bit when idling is missing, if it ever had one.
I am am going to install one. The question is which wire on the AC do I tap into?
From a couple of wiring diagrams I have looked at, it looks like it should be the light green wire on the ac pressure switch.
Can anyone confirm that, or tell me if I am wrong and where to look?
Old Jun 26, 2019 | 10:07 AM
bmotojoe's Avatar
bmotojoe
Yes on the hot side, not the switched side. Low pressure cutoff switch.
