My 75 Coupe with stock 350 except no cat converter appears to have a manifold exhaust leak only on the right side. Ticking on idle from that side, kind of Harley-ish sound on acceleration, some backfiring if you let off the gas quickly. Feels like less pressure coming out of left tail pipe than right. Not much room on the right side, exhaust probably on 20 years.
Any tips on fixing this, best to just bring it to a shop or is it fixable in a home garage?
Your best bet right now is to buy some PB Blaster and start spraying the six manifold bolts, everyday, for 3-4 days. If the leak is the gasket between the manifold and head, you can change those out sometimes without removing the manifold entirely. You will need a 1/2" gap to scrape the old gasket out and insert the new.
Some gaskets are made to drop in with the bolts still attached. If not, just cut a slot into the bolt hole.
