Driveshaft and Differential
Old Jun 28, 2019 | 05:53 PM
sunflower 1972's Avatar
sunflower 1972
Default Driveshaft and Differential
I'm in the middle of removing my diff. I just pushed the driveshaft as far forward as it would go into the trans. Shouldn't be a problem dropping the diff now. Should it? Most of the threads I read about this state REMOVE the driveshaft.
Old Jun 28, 2019 | 06:44 PM
'75's Avatar
'75
It will be fine the way you are doing it. Enjoying the warm albeit wet weather?
Old Jun 28, 2019 | 11:15 PM
bazza77's Avatar
bazza77
Enough room there to drop the diff straight down but I would be concerned about the damage ? to your snubber bracket as well.
Old Jun 29, 2019 | 03:42 PM
Plasticfreak's Avatar
Plasticfreak
Just unbolt that..........
Old Jun 29, 2019 | 06:16 PM
sunflower 1972
Thanks for the confirmation. Weather wise, yes. It's about time it got warm. The spring was terrible. I'll get the diff down in the next few days. I haven't decided yet if I should just replace the worn side yokes, or go with an exchange unit from Vtech in Rockford. I guess I'll decide once I get it down, get the cover off and take a look inside.
To Driveshaft and Differential
