Smaller mechanical fuel pump
Old Jun 29, 2019 | 07:58 AM
Aussie79vette's Avatar
Aussie79vette
Default Smaller mechanical fuel pump
I currently have mechanical fuel pump on my 350 in the 73, as Im in Austarlia it has been converted to Right Hand Drive.
The fuel pump is actually hitting on the aftermarket engine mount and I need to get clearance.
First option is to try and rework the mount bracket and get the clearance or the second option is to get a smaller fuel pump.
The current fuel pump is about 93mm across.
Does anyone know of a smaller mechanical pump as this would be the easiest fix and would be easier to replace now as the motor is out.
Old Jun 29, 2019 | 09:09 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
The Holley high performance one is definately shorter but I doubt that the diameter is any smaller. No return line either. You might be better off converting to an electric pump and just putting in a regulator.
Given the effort required. I’d think modifying the engine mount would be easier.
Old Jun 29, 2019 | 10:42 AM
jackson's Avatar
jackson
These looked promising but there were way too many failures ... now long gone.
https://www.hemmings.com/blog/2007/0...cal-fuel-pump/
? maybe re-engineered by another maker & similar is avaiilable ... don't know?
? what are other aussies with RHD C3 doing? Electric pump?
Old Jun 29, 2019 | 11:01 AM
OldCarBum's Avatar
OldCarBum
My 73 big block did not come from the factory with a return line from the carb or the fuel pump.
Not sure if the small blocks did.
If there is a clearance issue, you might look at other motor mounts if the brand you are using has a clearance issue.
With the engine out it would be the time to do it.
Other than that the option of installing an electric fuel pump would work with a pressure regulator so you can set the proper fuel pressure at the carb.
Old Jun 29, 2019 | 08:31 PM
bazza77's Avatar
bazza77
Another dodgy back yard conversion ? Do you have the engineering papers for the work ?
How about a close up picture of the job ?
To Smaller mechanical fuel pump
