Running rough
Old Jul 1, 2019 | 07:13 PM
gabesaad10's Avatar
gabesaad10
Default Running rough
I had just rebuilt the carb and it’s acting the same as it did before I had rebuilt it, it would idle kinda high at 1000 then after a little drop down to 750 then I’d drive it and I’d put it in neutral or it will shut off(might be cause the big can I put in), but then if I floor it it would stick at 2000 and then it would just want to shut off after that, anyone have any thoughts?
Old Jul 2, 2019 | 05:35 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
vacuum leak, choke issue or linkage issue. Have you checked your timing as well. what are you set at?
Old Jul 2, 2019 | 07:23 PM
gabesaad10's Avatar
gabesaad10
I can’t remember what we set timing at but timing is good, I haven’t put any of the vacuum lines back I just plugged the 3 (not the distributor or brake booster vacuum lines), what do u mean by linkages? And I had my auto teacher set the timing and set the choke, but I feel like the choke might be the culprit but I’m not sure how to set it
Old Jul 3, 2019 | 03:19 PM
Rescue Rogers
Contact Lars here on the sight. He only uses email, no messeages. There are some threads showing the linkage and how it should look if yo do a search. It sounds like your idles are set too low. My high idles is atleast 1500 rpm, then it kicks down to 1000 or so, once its warm it will drop again to 750 where its set. If your shop teacher set the timing to factory specs then its too low. That would be factory emmissions specs which really hurt the horsepower numbers. Ask Lars or his timing papers, as well as his carb papers. I'm guessing you have a factory Quadrajet, what extactly is your carb. Can you post pics as well
Lars email
V8FastCars@msn.com
Old Jul 3, 2019 | 04:27 PM
gabesaad10's Avatar
gabesaad10
I agree that the idle is to low but why would the car get stuck at 2000 rpm?
Old Jul 3, 2019 | 04:34 PM
Rescue Rogers
Sticking throttle cable?
Old Jul 3, 2019 | 04:36 PM
gabesaad10's Avatar
gabesaad10
No it’s not that cause it would only happen when the car is warm, and I tried to see if that was the case but everything was fine
Old Jul 3, 2019 | 05:02 PM
HeadsU.P.'s Avatar
HeadsU.P.
A binding in the secondary throttle shaft?
A throttle blade hung-up on the carb base gasket?
A binding in the link between primary & secondary shafts?
A weak or incorrectly installed throttle shaft "spring"?
A throttle return spring hooked in the wrong location?
Old Jul 3, 2019 | 05:10 PM
MelWff's Avatar
MelWff
what year is the car?
what engine is in the car?
what carburetor is on the car?
can you post a picture/s of the carburetor and the connections to it?
Old Jul 3, 2019 | 05:45 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Choke.
Old Jul 3, 2019 | 05:50 PM
gabesaad10's Avatar
gabesaad10
It’s a 1977 it has a 4 barrel Rochester
gabesaad10's Avatar
gabesaad10
Originally Posted by JBrooke825
Choke.
What should I do to remedy it?
Old Jul 4, 2019 | 07:21 AM
JBrooke825's Avatar
JBrooke825
You would be better off talking to Lars. Mine is a 69. He will have the answers for you.
good luck.with your problem.
Old Jul 4, 2019 | 11:34 AM
gabesaad10's Avatar
gabesaad10
Wait who is Lars?
To Running rough
