Runs Great but...
I am having a annoying problem.
My car starts and runs great normally.
If I stop and shut down after driving for a while, then restarting after about 15 minutes or so, the engine starts fine, but I only get about 100 yards and the engine dies and won't restart.
Looking into the carb and working the throttle linkage gets no fuel from the accelerator pump jets.
If I wait for about 15-30 minutes,and crank the engine a bit, checking the carb for fuel flow shows fuel available. The engine will then start and run well.
Previously, this occurred only after driving and then stopping for a while. Never died while driving.
Recently, the engine has died while driving around town. Will not restart until the above procedure is done. Cool down, and crank to refill the bowl.
Have changed the fuel pump, checked return fuel line clear, insulated line from pump to carb, changed filter.
Good solid pressure at 7-8 psi on gauge.
ideas?
ideas?
