Total mechanical advance question
Old Jul 27, 2019 | 12:26 PM
BBCorv70's Avatar
BBCorv70
I installed new springs as recommended, all in now by 2500 RPM.
The mechanical advance appears to have a range of 24 degrees.
Once fully warmed up,engine detonates with full advance at 38 degrees.
Had to back down to 36 degrees.
When I set my max advance to 36 degrees, I end up with 12 degrees at idle.
Ideally I'd like to idle at 18 degrees but would need to have the advance slot modified to achieve this.
Other than smoothing the idle a bit more, what would I gain between 1500 and 2500 RPM if I were to have the distributor modified?
Any noticeable increase in torque?
Car has 3.70 gears.
I can live with the slightly lumpy idle, wondering if it's worth modifying the distributor to limit the advance.
This is a weekend driver.
Old Jul 27, 2019 | 12:45 PM
derekderek's Avatar
derekderek
if you are all in by 2500, check timing at 1500 with and without vacuum. you may be just fine.
Old Sep 7, 2019 | 09:31 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
You could limit the vac advance to 10 degrees, via a stop, and then make sure it uses manifold vac, so it will kick in at idle. Then you may be fine with 10 or 12 initial, it'll be 20 with the vac.
Old Feb 26, 2020 | 05:58 PM
jvmagic's Avatar
jvmagic
Originally Posted by MelWff
You need to buy the spring kit that Lars recommends, Mr Gasker 928G. It comes with springs and a brass stop bushing. You will have to remove and disassemble the distributor to install the stop bushing. The original bushing was nylon and is either gone or on the verge of falling off. Using the original weights install the silver and black springs and then you can set your total timing to 38 degrees using a timing tape or dial back light.
If I follow this correctly, I need to install the stated springs/bushing and set my timing to 38 at say 3k RPM then at idle, set the timing to a certain reading or leave alone when I get 36 - 38 at 3k RPM?
Thanks in advance.
Old Feb 26, 2020 | 08:26 PM
MelWff's Avatar
MelWff
Thanks in advance.
once you set the timing at 3k, you check what the idle timing is but do not reset it.
Old Feb 27, 2020 | 10:25 AM
lars's Avatar
lars
...unless the resulting timing at idle is way out of the desired/acceptable range, in which case the distributor itself needs to be reworked to produce an advance curve of the desired length.
Lars
Old Apr 21, 2021 | 04:59 PM
Cliff R's Avatar
Cliff R
"You built the QJet for my '72 LeMans and I got the parts from you when I rebuilt the QJet on my '71 Corvette. Thanks for making my cars run so well."
You are most welcome. It's nice to now be officially retired, but I'm not out of the game, just slowing down some.
I've built the parts business to a point where I don't need to work on any carburetors so keeping that for a while. Still doing a few carburetors and custom tuning couple of Saturdays a month for the beer fund!.........
Old Apr 21, 2021 | 05:40 PM
MelWff's Avatar
MelWff
is that Cliff R as in Ruggles? Have your Quadrajet book, excellent. Not sure though who you quoted at the beginning of your post because I don't see any LeMans mentioned in this thread.
Old Apr 21, 2021 | 06:00 PM
derekderek's Avatar
derekderek
i think related thread struck again.
