Locks "clicking" continuously
Old Jul 11, 2019 | 10:11 PM
mcookgraphics's Avatar
mcookgraphics
Default Locks "clicking" continuously
1981 starting having issues with battery drain, then noticed the drivers side door lock clicks (doesn't actually lock, just makes a noise) about every 30 seconds, even after car is shut off. Pulled the fuse for temporary fix. Anyone had this issue? Any suggestions? Has power door lock. Thanks.
Old Jul 12, 2019 | 07:25 AM
Edward Ackley's Avatar
Edward Ackley
Default locks
I have the same problem, but live in north west florida and it,s hot here. with that said I plan on rebuilding my power locks in both doors this fall, there are some good videos on this subject if you do a search, you mentioned you have disconnected your battery, I also have a battery disconnect on mine you can purchase for $10.00
Old Jul 12, 2019 | 12:15 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Could be a bad ground or a broken wire that's just touching enough that a vibration is causing a connection that cycles the lock actuator or relay like an annoying co worker.
I would think bad ground or bad switch first
To Locks "clicking" continuously
