You are correct that they are originally there for assembly line purposes. My 1969 still has the originals, I believe I had them surfaced once since 1973 when I bought the car.
ok, so rivets are more than assy line convenience. the rotors need shimmed on these cars to remove runout. so they rivet the rotor to the hub and machine the runout out. so an orig riveted set SHOULD be flatter than a new replacement.
Adding my voice to the many miles on original rotors. Mine on my 1980 are at 90k. Rivets were on until I had the trailing arms rebuilt. At that time the original rotors were turned with no problem to meet factory spec thickness for post turning min thickness. Longevity in my opinion is due largely to the use of organic pads. When i see the wear on rotors from semi-metallic, metallic, and ceramic pads it is disturbing. Yes, I know they provide superior braking, but how much is that really needed on these older vettes in most cases. If my brakes get wet it's because I didn't expect rain. And the large surface area of vette brake pads coupled with large rotors will dissipate a lot of heat. Doing 60 mph and hitting the brakes just above the limit of locking up and going to a dead stop will literally create sufficient deceleration to give most people a head rush. So I'll continue to use the organics as long as someone makes them.
