69 c3 wiring diagram
Old Jul 20, 2019 | 10:14 AM
Bhebert449's Avatar
Bhebert449
Default 69 c3 wiring diagram
I would like to replace the engine wiring harness in my 69 c3. Looking for a good wiring diagram and Dr Rebuild was recommended. Can anyone tell me if the below linked diagram includes the engine wiring. The description says dash wiring diagram.
https://shop.docrebuild.com/1969Corv...utAirCond.aspx
Old Jul 20, 2019 | 09:16 PM
Z06CE's Avatar
Z06CE
I have these diagrams and it does include the front headlamp, ignition harness, rear harness, Transistorized Ignition diagrams
Old Jul 21, 2019 | 07:51 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I have a stack of different schematics and diagrams. some I added color to, others that I bought that way. Docs is unbeatable for identifying plugs and where they go, the actual color schematics make trouble shooting easier. I would buy both of Docs diagrams for your car, and a full color lamainated schematic as well. Heres some I would use in addition to the one you found. Willcoxs' isnt color but its a good one from Lectric Limited. I also use Lectric Limited harnesses and they lay out and fit like stock. I have good luck with their switches too. I think Willcox stocks their stuff, you can ask, but I believe Ernie Bench tests alot of his products. So support willcox if you buy their stuff.
https://shop.docrebuild.com/1969Corv...mpsRearPW.aspx
https://www.ebay.com/itm/1969-69-Cor...MAAOSwNphWXarb
https://willcoxcorvette.com/corvette...-diagram-53-82 you have to tell them which year
Old Jul 21, 2019 | 09:25 AM
Bhebert449's Avatar
Bhebert449
Thank you! Is the EBay and Wilcox listing the same diagram just different versions?
Old Jul 21, 2019 | 05:13 PM
Rescue Rogers
different versions, Willcox is a single color. Ebay is multiple colors. I have both just in case there is a difference
Old Jul 21, 2019 | 05:19 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This one is free....
What I would do... click twice on the picture below, this will enlarge it. Then right click on the picture that opens, select copy image.
Then open your paint program on your computer and paste it in there. Next, save the file to your desktop.
This makes it nice since you can color trace any circuit and see where the wires are going. We have these for all cars 1953-1982 and use them almost everyday in our shop when we are working on a wire issue. If you trace out a wire, save it as a different file so you can keep track of it.
Willcox
Old Jul 21, 2019 | 05:20 PM
Rescue Rogers
best deal of the day!!!
Old Jun 15, 2023 | 11:49 PM
Jmweave's Avatar
Jmweave
3rd Gear
Default This guy canceled my order
I tried to order a copy of the diagram and this guy sent me the following , " YES or NO: Are you or were you an NCRS member? Be Honest. Dishonest replies are cancelled. They are ! : No
I don't play games.
You know what they say ... Fk around and find out." I didn't even know what NCRS was.
Old Jun 16, 2023 | 05:09 AM
Rescue Rogers
If you order from Doc Rebuild do it over the phone. Its easier
Old Jun 16, 2023 | 12:41 PM
robertea's Avatar
robertea
Default A colorized version of the original GM drawings with corrections.
I scanned in the original GM wiring diagrams and then redrew them in color correcting a few mistakes that GM made.
Also added the K66 option which is the Transistorized Ignition.
I made it into a PDF as it is quite large in size (about 15,200 x 4,900 pixels) and as a PDF you can zoom or shrink it quite easily.
Also, it is free!
Old Jun 16, 2023 | 12:58 PM
Jmweave's Avatar
Jmweave
3rd Gear
Thanks Robert. This is exactly what I needed... Now the hunt for the problem begins! Thanks again.
Jeff
Old Jun 16, 2023 | 03:36 PM
robertea's Avatar
robertea
Jeff, You're welcome! If you find any mistakes or something that could be added let me know.
I have made a number of revisions since I first started this project.
Old Jun 18, 2023 | 10:29 PM
azhodge's Avatar
azhodge
Default wiring diagram.
I have several, but the ones from classic car wiring.com are great. If it is not in color then forget it.
To 69 c3 wiring diagram
