Testing steering column Switches
Old Jul 20, 2019 | 11:43 AM
Z06CE's Avatar
Z06CE
Default Testing steering column Switches
I have a 69 with Tilt Tele.
I have the steering column out.
The ignition electrical switch was intermittent. I replaced it and checked it out with a ohmmeter..all good.
Now I want to check continuity for the turn signal switch, hazard switch and horn through the harmonica connector.
I can't find a electrical diagram shows how the switches are wired to the harmonica connector. I found the horn terminal on the G terminal. When you press the horn button it should have continuity between the G terminal and the end of the steering shaft. Its intermittent I have a bad horn switch.
But how do I check continuity for the other switches.
I also found the key alarm terminals E and F...checks out good.
Thanks for any help.
Mike
Old Jul 20, 2019 | 02:45 PM
GunPowder's Avatar
GunPowder
Had the same problem some time ago (12 years?), so I noted the connections between the switches and the harmonica connector while I was in...
Hope this helps...
Old Jul 20, 2019 | 05:57 PM
Z06CE's Avatar
Z06CE
Thank you so much! Just what I was looking for!
Mike
Old Jul 20, 2019 | 06:34 PM
Z06CE's Avatar
Z06CE
Checked out the flashers all good.
I read a high resistance on terminal J right front signal...
39 ohms.
And terminal N Right Rear signal..... 3 ohms
Do I need to replace the signal switch?
Horn is intermittent. Needs fixed.
Old Jul 21, 2019 | 02:21 AM
GunPowder's Avatar
GunPowder
Sounds more like an issue with the switch contacts. Cleaning them might help. Check also the harmonic connector contacts.
Old Jul 21, 2019 | 07:55 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If you didn't know, use a pencil eraser or a chemical cleaner on the contacts for best results, be careful of your paint and anything plastic with the sprays
Old Jul 21, 2019 | 07:06 PM
Z06CE's Avatar
Z06CE
what is a acceptable for a ohm reading between the Horn Terminal G on the Harmonica connector and the shaft of the steering column..... I'm reading 430 ohms when the horn button is pressed.
Old Jul 22, 2019 | 02:37 AM
GunPowder's Avatar
GunPowder
Are you sure you have a good ground for the measurement (steering column shaft properly grounded)?
Since this is a simple (from an electrical point of view) contact, it should be close to 0 Ohm.
But from a mechanical point of view there are a few components involved which might sum up to high ohms reading (when corroded / stained / weak).
Old Jul 22, 2019 | 01:57 PM
Z06CE's Avatar
Z06CE
I read 1 ohm from the end of the shaft to the hub... I'll call that good. But from spring loaded plunger to the horn terminal on the harmonica connector it reads 450 ohms.
I think I have to remove the plunger to inspect it.
To Testing steering column Switches
