manifold choice
For what its worth, I believe Edelbrock has a soft carb spacer, maybe quarter inch thick, and is a two hole design. Meaning divided left / right just like the 7501 plenum is.
The spacer even has a divider down the middle.
Wouldn't that be better than a four hole spacer, which the Eddy 7501 is not a four hole? Cooler charge for the carb, not too high to clear the hood and being somewhat soft material will have a good seal. I suppose the spacers dividing wall cut be removed with a razor blade.
I recommend the four hole because, as an extension of the Venturi....it lengthens it and will pull on the booster a touch harder....same theory as a HVH Super Sucker.
You might make more peak power with an open spacer on an Air Gap...but the curve will suffer down low....
The standard RPM is even more touchy because the divider is not “cut out” like the Air Gap.....
Jebby
Shoot-out: Carb Spacers; 4 hole vs 2 hole vs open style. On the next Motor Trends Engine Masters!!!!!!
