1972 corvette radiator hoses
Old Jul 26, 2019 | 09:56 PM
Tom Johnson1965's Avatar
Tom Johnson1965
4th Gear
Default 1972 corvette radiator hoses
I’ve been trying to find the right hoses for
my 72 base 350 4 speed non a/c . Thanks to a google search I foun a thread here and found the right lower hose #3917669 . Does anyone know what the upper hose # would be Thanks in advance
Tom
Old Jul 26, 2019 | 11:41 PM
BarryB72's Avatar
BarryB72
This is what I put on mine.
I believe this engine compartment is pretty much stock if you have any questions.
And yes, I have a 669 lower.
Old Jul 27, 2019 | 08:03 AM
Kaper220's Avatar
Kaper220
Hi Tom,
if you are looking for a original upper hose. I saved mine. I am willingly to sell.
Mark F.
Old Jul 27, 2019 | 08:34 AM
Tom Johnson1965
4th Gear
No I’m not looking for original . I’m just trying to get the right hoses . But thanks for your help
Old Jul 27, 2019 | 09:06 AM
Kaper220's Avatar
Kaper220
Tom, the correct # is 3935466, I purchased mine on Zips , good price & received quickly. Fit Perfectly.
Good Luck
Mark F.
Old Jul 27, 2019 | 10:02 AM
BarryB72's Avatar
BarryB72
Sometimes I wonder if I'm the only one that can see my posts
Old Jul 27, 2019 | 05:29 PM
mortgageguy's Avatar
mortgageguy
Changing that bottom hose is fun.
Old Jul 27, 2019 | 05:33 PM
jim2527's Avatar
jim2527
Speaking of bottom hoses.... parts guy at NAPA was telling me hose companies are doing away with springs in lower hoses. Says its causes corrosion compatibility issues. I tried not to laugh. But they didn't have any with springs. I googled and couldn't find anything about it. B.S.?
Old Jul 27, 2019 | 05:37 PM
theandies's Avatar
theandies
That's what I have on my 1971 Base engine without AC
Old Jul 27, 2019 | 05:39 PM
theandies's Avatar
theandies
Parts guys are usually wrong. I wouldn't run my bottom hose without the spring. If I couldn't find a hose that came with a spring I'd use the one out of the old hose.
Old Jul 28, 2019 | 07:35 AM
jim2527's Avatar
jim2527
Exactly what I did.
Old Aug 4, 2019 | 09:39 AM
Tom Johnson1965
4th Gear
Default Thanks
Thanks for
all the help
Old Aug 5, 2019 | 03:19 PM
7T1vette's Avatar
7T1vette
You can buy "non-collapsing", corrugate hoses which do not require the internal support spring. But, they don't make such a hose the "looks" like an OEM part. If the spring is in the hose you remove, swap it over to the new hose. Or, you could make your own 'support spring' by winding some stainless steel wire to the correct diameter.
Old Aug 5, 2019 | 06:40 PM
Tom Johnson1965
4th Gear
Default Lower hose
The new lower hose from Eckler’s came with a spring in it
Old Aug 8, 2019 | 05:05 PM
mrvette's Avatar
mrvette
Some time ago, I cut the lower hose angle fitting off my replacement aluminum rad, and fit on a short elbow hose, into a 1.5 inch brass plumbing coupling like for sinks/etc.....and then into one of them spring looking hoses with reinforcement inside to the pump.....been there for years now.....
To 1972 corvette radiator hoses
