79 Corvette transmission issues
Now I know everyone will say it low on fluids, but it is not. And when I had the car apart I replaced all the seals in the transmission and changed the filter and has all new fluid. And as I said, I have drove several short trips in it and a good 100 mile trip in without any issues with the transmission, this was just all of a sudden. There is a vacuum line that goes form the carb to the back of the transmission, which seems weird to me and I question that. I attempted to move that vacuum to another place but it did nothing. Is it a pump? Torque converter? Or something simple (I hope) that I am not seeing. I had hoped to get this painted and taking it to a car show I was going on August 15 but I think I am going to miss that now, which sucks.
Once again, sorry for the lengthy post, just wanted to say everything I have done. I have searched but can't find anyone with this particular problem. Hope someone out there is a transmission guy. This is the TH350.
I wonder if that's what was actually leaking and not the cooling line fittings? Those modulators can be purchased that are adjustable also. This would change the RPM at which the tranny shifts 1-2 and 2-3 either higher or lower.
The fact that the tranny was recently rebuilt tells me something was left out or the valvebody is loose or the front pump is wonky. IDK
Before you think about pulling the tranny, you might want to drop the pan and have a look around for something amiss.
Also, were do the cooling lines go to? Still go to the Rad? Any mods done recently? New cooler?
Maybe trans was low on fluid as you First backed it out / Before your 100-mile ride / During your 100-mile ride ? ...
... Maybe you drove w/ low fluid & smoked band / frictions ?
Hopefully, it's Not too serious ... But if it is ... agree w/ OverDrive replacement trans.
Your cars tranny runs just long enough to empty the trans pan, then stops. Wait a few minutes for the fluid to refill the pan and its fine again.
H-m-m-m-m-m-. I vote a blockage somewhere. I don't believe its the front pump. But you are running out of fluid & pressure soon. What's the history of the pan filter?
Is there a kink in the return cooling line from the radiator? The kink could be in the rubber hose section near the Rad.
As you know, you can't build pressure if there is no fluid in the pan.
If the pan is running dry, that would explain the short distances before things begin to happen. But where is all that fluid going? Or, why isn't the fluid returning to the pan, might be a better question. IDK
Torque Convertor issue? Over full? No return of fluid? IDK
Ask if he can diagnose without pulling trans ? and how much ?
It'll be worth Your time & $ to know from a real pro ... and to pay him accordingly.
Lotsa auto trans choices: pay to have your 350 rebuilt, buy rebuilt replacement 350, buy a junkyard 350, retro-fit a 200r4 or 700r4.
With a reliable diagnosis & quote in hand, you'll be equipped to make best choice for you.
