A/C temp switch insualtion
Old Aug 3, 2019 | 02:02 PM
manfroni's Avatar
manfroni
Default A/C temp switch insualtion
Any ideas on what to use for the temp switch insulation? The old stuff looked like a black putty
thanks
Old Aug 3, 2019 | 03:25 PM
speedreed8's Avatar
speedreed8
This is what I used on my 79. From Lowe’s
then I put that aluminum foil tape over that.
Old Aug 3, 2019 | 08:29 PM
Hammerhead Fred's Avatar
Hammerhead Fred
thanks
The sensing bulb is wrapped in A/C Insulation Refrigerant Tape available at most parts stores.
Also known as Prestite Tape or Tacky Tape
Old Aug 3, 2019 | 10:38 PM
interpon's Avatar
interpon
I was wondering as well..its like a putty not a tape..wonder what happens if not insulated as mine is crumbling..
not easy to tape
i have this..wonder if will work..ill try
https://www.lowes.com/pd/gardner-ben...E&gclsrc=aw.ds
Old Aug 4, 2019 | 06:44 AM
Rotonda's Avatar
Rotonda
https://www.amazon.com/Rectorseal-81880-1-Pound-Duct-Compound/dp/B008A3UG94/ref=sr_1_3?gclid=Cj0KCQjwhJrqBRDZARIsALhp1WSnqzQOpvJELUQ1ojhNM8A3zHEn1Niem4R-zrYNApw7WTETW7dtqbkaAidpEALw_wcB&hvadid=153714081264&hvdev=c&hvlocphy=9012295&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=2890214839777413435&hvtargid=kwd-5533093804&hydadcr=8432_9505422&keywords=electrical+putty&qid=1564915173&s=gateway&sr=8-3 https://www.amazon.com/Rectorseal-81880-1-Pound-Duct-Compound/dp/B008A3UG94/ref=sr_1_3?gclid=Cj0KCQjwhJrqBRDZARIsALhp1WSnqzQOpvJELUQ1ojhNM8A3zHEn1Niem4R-zrYNApw7WTETW7dtqbkaAidpEALw_wcB&hvadid=153714081264&hvdev=c&hvlocphy=9012295&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=2890214839777413435&hvtargid=kwd-5533093804&hydadcr=8432_9505422&keywords=electrical+putty&qid=1564915173&s=gateway&sr=8-3
The above, Duct Seal Compound, is what I used on my Vintage Air install. Easy to use and seems to be permanent.
Old Aug 4, 2019 | 08:47 AM
Hammerhead Fred
not easy to tape
That's not for use outdoors so may not hold up in the long run.
It's important to the proper operation of the A/C that the sensing bulb be held tight against the pipe AND insulated against the outside heat from the engine compartment.
Old Aug 4, 2019 | 09:59 AM
interpon's Avatar
interpon
Originally Posted by Rotonda
https://www.amazon.com/Rectorseal-81...gateway&sr=8-3
I shall try this thanks
To A/C temp switch insualtion
