How much play is acceptable- hei
Old Aug 13, 2019 | 04:53 PM
Dusky's Avatar
Dusky
Default How much play is acceptable- hei
The video says it all
First I'm spinning it CCW then CW. too much play?
Im still looking for the cause of my idle jumping 50 rpm sometimes.
Anyway, is this too much wear/play?
www.youtube.com/watch?v=W5usgv4yGKM
https://www.youtube.com/watch?v=W5usgv4yGKM&feature=youtu.be
https://youtu.be/W5usgv4yGKM
Old Aug 13, 2019 | 04:56 PM
jackson's Avatar
jackson
How 'bout you just tell us ...how side play? ... how much end play?
Old Aug 13, 2019 | 05:10 PM
Dusky's Avatar
Dusky
You tell me - a few millimeters 🤷*♂️
Old Aug 13, 2019 | 06:11 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
That needs to be replaced or rebuilt. The up/down, it's trying to climb the cam gear. there looks like an excessive amount of play in it. Probably cheaper and definitely faster to replace it.
Old Aug 13, 2019 | 06:16 PM
Mooser's Avatar
Mooser
HEI are known for excessive end-play
If you hold the rotor down and try wobbling it sideways without letting it climb, there shouldn't be much movement
check this thread, you can shim or ignore
https://www.corvetteforum.com/forums...clearance.html
M
Old Aug 13, 2019 | 06:38 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Way to much end play clearance, that much climbing will change your timing.
.010 to .015 for aluminum distributors
.005 to .007 for cast Iron distributors.
Funny I just saw a thread on this the other day.... .I have these specks on a poster sign right behind my distributor machine. Pull the distributor and check the end play
Willcox
Old Aug 14, 2019 | 02:59 AM
Dusky's Avatar
Dusky
Cheers guys
At this point it'll probably be cheaper buying a new HEI.
"local" shop has an MSD streetfire HEI in stock, so it'll probably be that.
Old Aug 14, 2019 | 07:27 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The distributor, due to how the orientation of the helic on the camshaft will not allow the distributor to "climb"...........the only time this may happen is during hard deceleration from a very high RPM.
It is still good practice to keep the endplay in spec. I like .010 to .015.
Jebby
To How much play is acceptable- hei
