How to assemble a '77 Corvette
Aug 13, 2019 | 07:23 PM
1. Assemble the mounting and adjustment brackets to the power steering pump and hang from the ceiling by a rope
2. Assemble the rest of the car around them
Aug 13, 2019 | 07:37 PM
Just another Corvette guy
Aug 13, 2019 | 07:39 PM
Just like a heater core. Put the core on a box, then assemble the rest of the dash, then the rest of the car around it.
Aug 13, 2019 | 07:46 PM
Easier than changing a radio in a 79. Pull the engine disassemble the firewall. In do the ***** and mounting nuts cut big hole in firewall unplug wires remove radio reverse procedure . And you want to assemble an entire car?
Aug 13, 2019 | 10:09 PM
By Jove!! I think you've got it!!!!
Aug 14, 2019 | 01:43 PM
Interesting. I was always taught the correct order was:
1. Remove fasteners from hood ornament and attach to hoist.
2. Raise hood ornament and drive new car underneath.
3. Lower hood ornament and reinstall fasteners.
Aug 14, 2019 | 10:22 PM
No, just jack up the radiator cap an drive the new car underneath. No sense doing unnecessary steps.
Aug 14, 2019 | 11:27 PM
I almost did that. Old accord kept emptying cooling system. Almost put an engine in it. Then i realized rubber gasket was gone from radiator cap.
Aug 15, 2019 | 12:35 AM
There are a few pieces on these cars that everything else seems to have been built around:
- heater core
- rear body mount nut retainer on a convertible (the second part on the assembly line was the reinforcement plate)
- speedo and tach light bulbs. (Followed immediately by the light switch)
Im sure there are many others.
Aug 15, 2019 | 09:08 PM
Just removed radiator on a big block:
Hood first, then alternator, fan, upper hose, brackets, shroud, core support, radiator, the lower heater hose came out last!
Whew!
