Low voltage with accessories - Change alternator?
Old Aug 16, 2019 | 06:37 PM
DC3's Avatar
DC3
Originally Posted by Richard454
The "whine" in car audio is due the AC ripple not filtered by the alternator entering the AC -speaker level or most often pre-amp 500mv level. Quite often due to different impedances between the radio and amplifier- and most of the time due to a lesser quality amp and or cheap unshielded RCA cables-
Chasing the whine can be frustrating. I used quality components and cables, installed them correctly and still got a slight whine. I put filters on both the 12V switched and 12V battery leads to the head unit which took care of most of the whine. I did get rid of the whine completely for awhile by installing a capacitor across the alternator based on a thread somewhere on this site. But, I couldn't keep the recommended capacitors from failing. It may have been a heat issue.
DC
Old Aug 16, 2019 | 07:05 PM
Richard454's Avatar
Richard454
DC
Back in the day- I put myself through college installing car stereos...I then worked for Kenwood and my first real job was the technical help line- so I'm pretty familiar with the frustration!
Like I said- the alternator IS the source of the whine-as the AC voltage- IIRC was around 100HZ at idle and changed (up in frequency) with RPM that is introduced in a DC system.
So you could filter it at the source by a cap or everything powered off the battery or have equipment that has isolation circuits to not let the AC in the pre-amp section.
My point still being- add all the grounds you want - it will not hurt anything NOR increase ( could possible decrease) alternator whine in the stereo system.
Richard
Old Aug 16, 2019 | 07:46 PM
DC3's Avatar
DC3
Richard
Completely agree with you on the grounding. For ground loops to be an issue, there would have to be a potential difference between one or more grounding points. I went down this road with a fairly sophisticated Fluke meter and always got zero voltage between any two grounding points on my '73. My experience was adding the alternator to frame ground cut the whine down a bit but did not eliminate it.
It is a Kenwood system on my '73. Amp is direct to battery as is the 12v battery lead to the head unit. But, the 12v ignition wire to the head unit comes from the fuse block. I suppose I could add a relay so as to have both 12v leads to the head unit being supplied directly from the battery. Hadn't thought about that before. Hmmm.
Do you have a recommendation for what type of capacitor I could put across the alternator that would filter out the whine and withstand the heat and vibration of the engine compartment?
DC
Old Aug 16, 2019 | 09:03 PM
Richard454's Avatar
Richard454
DC
The radio (Kenwood started this in the late 80's) uses the ignition wire to just trigger the radio on- that should not be a source of noise. If the constant power (yellow wire) is connected to the battery AND the ground- you might have a bad- or rather going bad alternator. Take your meter- turn on the headlights and see how much AC power is showing up at the battery- more than 500mV- diodes bad.
A top quality noise filter would be the "Newmar" ones out there- marine quality- just do a google search to find them.
Richard
Old Aug 17, 2019 | 01:18 AM
augiedoggy's Avatar
augiedoggy
In regard to the ground loop I just remember from installing stereo and amps many of the documentation as well as a book on car audio talking about having all the grounds branching from the same source vs different sources and area of the vehicle and how grounding at multiple pionts of the vehicle can introduce noise.. Heres something I found quickly while googling it.
https://www.lifewire.com/whining-noi...x-input-534592
And yes Ive found that moving the ground source on more than one vehicle had resolved or reduced the whine.
In this case adding the additional ground to the alternator likely helped reduce it because it eleminated any existing difference in ground potential.
Old Aug 17, 2019 | 12:11 PM
DC3's Avatar
DC3
You make good points as well. I'm reminded of helping a friend many years ago chase down a whine in his stereo system. Despite all of the ground connections being good, we finally eliminated the whine by connecting three grounding points together with wire. Guess his frame just wasn't up to the task of being an effective conductor.
Apologies to the OP for derailing your thread.
DC
Old Aug 17, 2019 | 12:53 PM
Richard454's Avatar
Richard454
In this case adding the additional ground to the alternator likely helped reduce it because it eliminated any existing difference in ground potential.
The difference in potential ground between audio components- that is a problem.
When you have the difference in potential ground - say a bad ground or not optimal one on the radio- since electricity is lazy (likes the least amount of resistance) it's going to travel down the audio ground (shield on the RCA cable)- that acts as an antenna - picks up noise.
Same with the antenna cable- the antenna is grounded at the back of the car- if that ground is better than the one at the radio- then the shield cable acts as an antenna and will pick up noise too.
The alternator is what is GENERATING the noise...adding another- better ground makes it work less- more efficiently - that's why the noise is lower/eliminated- has nothing to do with a ground loop.
Old Aug 17, 2019 | 02:50 PM
scottjamison's Avatar
scottjamison
DC
Not at all.
I learned what I needed to and gained a whole lot more information. I like it!
Old Aug 17, 2019 | 03:03 PM
ajrothm's Avatar
ajrothm
Scott, switch over to a CS144 alternator and don't look back...(if you are running factory/repro brackets).
I got my High Output CS144 from www.alternatorparts.com about 10 years ago and it still charges great. A 140 amp alternator with good idle amperage is pretty much a MUST today when running fans, fuel pumps, FI etc....
If you are running a serpentine or other front runner type system, you'll have to find an alternator that works with that bracket system.
I have a thread here on CF tech from when I installed the CS144 alternator with pics, info, tips etc... It'll show you how you need to mod the "C" bracket etc.
