TH350 went KA-PUT
Old Nov 11, 2002 | 02:58 AM
8T1-7T9 BIONIC VETTE's Avatar
Default TH350 went KA-PUT
While driving around today in third gear trans makes bad metal grinding sound.....pulled over to check and nothing looks out of the ordinary....get back in and start to pull away in third....grinding noise again....shift down to first....no problem...shift up to second....no problem....shift up to third.....bad metal grinding sound....drove home in second.....Looks like the perfect time for the 700R4? :seeya Cappy
Old Nov 11, 2002 | 05:28 AM
kingdavidrules's Avatar
kingdavidrules
Default Re: TH350 went KA-PUT (8T1-7T9 BIONIC VETTE)
i have been hearing a clanking noise on turns that kinda sound like there coming from the transmission , what can i do to remedy this so i dont have to get a 700r4 ?
Old Nov 11, 2002 | 08:18 AM
page62's Avatar
page62
Default Re: TH350 went KA-PUT (kingdavidrules)
8T1: Sounds like a good enough excuse...
KingDavid: Your noise sounds like the posi differential binding on turns. Very common (mine does it too). The rear end probably needs a fluid change that includes some GM positraction additive (Ecklers sells a kit).
To TH350 went KA-PUT
