ECM just controlling Lock up Converter
Old Aug 23, 2019 | 11:29 PM
eddp's Avatar
eddp
Default ECM just controlling Lock up Converter
Carb and dist delete. HEI and non ECM carb. If I don't unplug, or disable ECM, will the ECM still control the lock up on the transmission and will the lock up converter work as it is supposed to work?
Old Aug 24, 2019 | 11:07 AM
terry82's Avatar
terry82
We will have to assume that you have a 1981 or a 1982 corvette.You can drive the car and see how it performs.It should work ,But I am not positive.The only imput that I know of for the computer to the tranny is the speed sensor, from the speedo cable on the back of the speedometer.[vss]
Old Aug 24, 2019 | 11:26 AM
eddp's Avatar
eddp
Default '81
Yes, it's an '81. Isn't there a fuse to the ECM that, if I pulled it, would would prevent the check engine light from staying on?
Old Aug 24, 2019 | 04:26 PM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
Default No Lock Up
My '81 has 2.87 rear gears and no lock up converter. I don't think a 400R 4th gear would be much different.
Old Aug 26, 2019 | 09:29 AM
fishslayer143's Avatar
fishslayer143
it is doubtful that pulling any fuse will turn OFF a Check Engine light.. pulling fuses usually TURN ON CEL
Old Aug 26, 2019 | 09:55 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Though I’m not certain, I really doubt the lockup will work with the Check Engine light on. Also, I don’t think the CCC got any input from the speedo but it did from the distributor. Since lockup only works in third gear, my guess is that it was RPM based.
Old Mar 18, 2021 | 11:06 AM
Roy W.'s Avatar
Roy W.
Keep in mind that your '81 has 2.87 rear gears. I'm not sure how an overdrive gear (4th in a 200R) will work, although the low 1st gear would be a definitle advantage.
Old Apr 16, 2021 | 05:11 PM
usmilret's Avatar
usmilret
Torque converter lockup happens when the turbine and the start are at relatively the same speed within the torque converter. How the '82 Corvette's ECM manages that is archaic.
Old Apr 16, 2021 | 05:23 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Let's call this a "Historical Need to Know Information Thread".
It has good info for members like me who are currently making engine/transmission changes.
Old Apr 16, 2021 | 05:37 PM
Mrvettenick's Avatar
Mrvettenick
The converter won't be engaged unless it's in closed loop mode. That being said, do you still have an O2 sensor.? Closed loop is based on O2 and coolant temp. are the main controllers as well as vehicle speed. Also your converter locks up in 2nd and 3rd gear. if the conditions are right.
Old Apr 16, 2021 | 06:14 PM
doorgunner's Avatar
doorgunner
Wow.....that adds up to 5 speeds 1st/2nd/2nd locked/3rd/3rd locked !
Old Apr 16, 2021 | 08:47 PM
Eric P's Avatar
Eric P
The only reason why lockup wouldn’t work on a 700R4 is if the brake light switch or TPS sensor was bad or faulty providing internal transmission electronics and ECM is good . Lockup controls Cooler flow on the 700 and it doesn’t flow until lockup so GM wants it to lockup just so it doesn’t burn up . For those that don’t want lockup Sonnax does sell a tcc valve that corrects cooler flow without lockup
if your 81 has a 3 speed T350C then no harm done if lockup doesn’t work but no lockup on a 700R4 will burn it up on 1982 Vettes . I did enjoy the lockup on my T350C in my 1980 but have since converted to 700R4 , the best single item change I’ve made to the car so far
Old Apr 17, 2021 | 12:11 AM
7T1vette's Avatar
7T1vette
Lockup is not anything like an overdrive gear. It merely eliminates the hydraulic 'linking' of the converter pump and turbine. At best, the rpm change when it goes into lockup mode is 200-300 rpm. There is a noticeable change is speed, but nothing like a major gear change.
Old Apr 17, 2021 | 08:14 AM
1860army's Avatar
1860army
I have an 82 with a crate 355, only thing the ECM does is the fuel pump, you can verify that by turning the ignition on but not starting. The pump will cycle for 2 seconds and then turn off if no demand. It will not lock up the TC and the only ways I know to do that is the B&M kit or what I have which is a pressure switch inside the trans that goes to ground when it hits forth and initiates the lock. The trouble is that it will lock it at slower speeds than I want especially when the engine is not fully warmed and possibly lug. two ways around that, keep it in 3rd when driving around town or putting another switch on the wire coming out of the trans and turning off the lock when not needed, I plan to add the switch and put it near the shifter. From what I was told by a good trans guy, not locking the TC will cause the temps to go up at highway speeds and might shorten the life of the trans. The RPM difference ,locked/unlocked, is 3-400 from what I see on my tach. I heard from a few trusted mechanics the the B&M kits are a bit of trouble but I have not experience with them. Good luck,
60
Old Apr 17, 2021 | 10:31 AM
doorgunner's Avatar
doorgunner
Best case scenario...
Every little bit helps: 200 rpm x 60 min x 5 hr. road trip = 60,000 rpm (un-used @ 60mph)
60,000 rpm / 3000 rpm @ 60mph = 20 minutes of wear you saved on your engine (@ 60 mph)
(did I do that correctly?)
To ECM just controlling Lock up Converter
