Engine Miss or Camshaft
Old Aug 28, 2019 | 08:09 PM
Bigb69's Avatar
Bigb69
Default Engine Miss or Camshaft
How can a novice tell the difference between an engine miss or loping camshaft without knowing any history other than it has been opened up, probably rebuilt at some point. Small block 350. TIA
Old Aug 30, 2019 | 04:15 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
You could give it a compression test(and leak down test) to eliminate valves and rings ,and ohm test your spark plug leads ,plus new plugs .Always start with the simple things first
Old Aug 30, 2019 | 07:49 AM
bashcraft's Avatar
bashcraft
I had a car that developed a miss while on a trip. I was convinced that it had lost a lobe on the cam. Turned out to be a bad plug wire.
Old Aug 30, 2019 | 04:25 PM
fishslayer143's Avatar
fishslayer143
connect a vacuum gauge to the intake or carb. it can tell you whats going on
Old Aug 31, 2019 | 06:07 AM
Bigb69's Avatar
Bigb69
A little update-Changed plugs twice, wires , cap, and rotor. Carb was sent off and rebuilt by a professional. Sounds like time for a compression and leak down test. The needle on the vacuum gauge is not steady but hovers around latent timing?? I guess now verify TDC, valve lash(solid lifters), and compression/leak down. What would be the logical order or does it matter? Thanks everyone for the guidance.
Old Aug 31, 2019 | 08:26 AM
flyeri's Avatar
flyeri
Under what conditions do you feel this miss? Cold or hot engine? Idle, light acceleration, WOT acceleration, cruise?
Old Aug 31, 2019 | 01:30 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If it is a lobe on the cam, you will hear it clacking almost immediately. And it wears down from that point at a very fast rate. It is doubtful that is what is going on with your engine as a lobe wearing off sporadically is very rare.
Check your ignition first. Then go to compression checks as stated above.
Jebby
Old Aug 31, 2019 | 03:54 PM
Bigb69's Avatar
Bigb69
It seems to be present while cold and hot, idle and light acceleration. I think it may still be there under WOT, just harder for me to detect it. The vacuum gauge will stay around 13 in and fluctuate 1 to 2 in.
Old Aug 31, 2019 | 06:25 PM
Jeffs82c3's Avatar
Jeffs82c3
I would use a stethoscope and check around for where the noise is coming from, they are not expensive to buy.
Old Aug 31, 2019 | 07:13 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
But the OP never mentioned there was a noise.
Jebby
Old Aug 31, 2019 | 07:24 PM
diehrd's Avatar
diehrd
Or did he mention any popping or clanking and clicking loud as hell.
A misfire is the least of what a wiped lobe does
Old Aug 31, 2019 | 09:07 PM
derekderek's Avatar
derekderek
Pull valve covers. Crank starter. Watch rockers. Bad lobe or pushrod will be obvious. If all 16 move the same amount, probably cam is fine. Check timing chain. If #1 exh is just closing and #1 intake just opening as tdc mark sez tdc, chain is in time. Now readjust lifters. Now get back to your ignition or fuel or vacuum issue.
Old Aug 31, 2019 | 11:22 PM
Bigb69's Avatar
Bigb69
My description was lacking. Not that I suspected a bad lobe on the cam but is it a more aggressive than stock camshaft with a lope, or misfire. I think it's probably time to pull the valve covers and have a look.
Old Sep 1, 2019 | 01:08 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Pull a spark plug wire. You will now hear what it sounds like with a miss. Go around pulling one wire at a time and see if one doesn't change the sound. If none of them change the sound and it sounds the best if they are all hooked up these is probably nothing wrong. If a cam Lobe has gone bad there will be slack in that Cylinders valve train and it will be making a ticking sound. A much different sound than a miss.
Old Sep 1, 2019 | 03:42 AM
c6_CJ's Avatar
c6_CJ
post a video
To Engine Miss or Camshaft
