Adjusting valve lash advice please
This method is for a street use / daily drivers engine that are not seeking to reduce ET by a tenth of a second.
Setting lash while running got a bad rep early on because of the oil spray, dripping oil on the exhaust, smoke everywhere. Now, there are spray clips to contain that or clever ways to use an old valvecover see post 3.
I just use a long piece of cardboard, two inches high, between the valvesprings and the valvecover ledge, plus the 8 clips. No spray. No dripping. No smoke. Fast, easy, fairly accurate.
(these topics are difficult, at times, because we try to be helpful to people who are unfamiliar with the process, but we don't know their level of expertise. What seems quite simple to us, may be VERY intimidating to someone with limited experience)
And the unfamiliar get even more confused/frustrated not knowing which method to choose.
You only need to get at the rocker nut at this time. So the more splash protection / more coverage the better. The spray clips will divert the oil but not shut it off completely.
No need for cover gasket and two bolts, on the bottom, finger-tight will hold the cover.
Thanks for all of the support
I am grateful for all the folks who have helped me.
I purchased the clips and reset lash while engine was running.
I must admit this is the way I will go in the future as i was able to back off the tension and hear as well as feel the tapping/clacking.
Slowly tightened up nut until tapping stopped then (2) 1/4 turns.
Engine runs great no weird noises and smoother.
Installed clips and made a deflector with foil. worked great
A year from now you will be able to hold a ratchet in one hand, a beer in the other.
