Adjusting valve lash advice please
Good luck - Don
I could set the lash on 5 engines by the time you figure out which cylinder is next in order on your first engine.
You just keep torqueing the snot out of the balancer bolt over & over again, and see where that gets ya.
Remember, its not a Pro-stock engine, its a daily driver.
But hey, your engine, do as you please.
Loosen rocker. Clack-clack-clack, tighten until it stops. Then 180* with your ratchet. Done! Next!
Use a 1/2" drive ratchet with a short extension. That will keep your knuckles away from the rockers. Its very easy, simple & accurate procedure. Start at either end of the head. Work your way across. Stop engine when done, remove clips, install valvecover. Do the other side.
I agree, but as I mentioned in an earlier post, sometimes the engine runs a little rough, once you begin to go beyond the "zero lash" point, and it might make a "rookie" a little nervous. That's why I suggested just tightening the nuts until the lifter stops clattering, then go to the next one and do the same thing, and when they're ALL at the "zero lash" point, just turn the engine off, and tighten them all 180*, as you mentioned.
One other thing....the "adjusting nuts" on the rocker arms are a "crimped thread, self locking" nut. HOWEVER, if you run them up and down a number of times, they WILL lose the tension on the locking portion of the threads, and they won't adequately lock anymore. If that occurs, and they back off, you'll have to replace the nuts with new ones. Don't go to the dealer for new ones, you'll pay $$$. Sealed Power brand nuts are good, and sold at Advance Auto, Autozone, NAPA, etc.
How you get it there doesnt matter. Use whichever method works for you.
Me too.... I just did it today actually.... This method is almost fail proof.... All of those other methods will confuse the **** out of anyone and asking for mistakes.
OP, here you go.... EOIC method. Now they are setting valve lash on a solid roller here, so its a little different then setting a hydraulic to "zero lash plus 1/2 turn" but...positioning the valves are the same method. EOIC.
When torqueing a rocker, the engine may run rough for 3 -5 seconds then smooths out.
l understand your method, but I think you jeopardize the ability to keep the engine running smoothly, long enough to finish the task. Setting one valve at a time means the other 15 valves are fine or close to. With your method 8 valves are awaiting their final position. You may actually hear all 8 clack-clack-clack.
(it seems that this topic comes up about once a year, and gets more involved, each time....)
This method is for a street use / daily drivers engine that are not seeking to reduce ET by a tenth of a second.
Setting lash while running got a bad rep early on because of the oil spray, dripping oil on the exhaust, smoke everywhere. Now, there are spray clips to contain that or clever ways to use an old valvecover see post 3.
I just use a long piece of cardboard, two inches high, between the valvesprings and the valvecover ledge, plus the 8 clips. No spray. No dripping. No smoke. Fast, easy, fairly accurate.
lol
