Trouble with warm restart
Old Sep 1, 2019 | 09:48 PM
jcnst1's Avatar
jcnst1
Default Trouble with warm restart
I’ll do my best to explain this, but wondering if anyone has the same issue. When I start my 69 L46 up cold, I slowly pump the gas peddle three times first and it usually takes 5 seconds to turn over and fire up with no problem. After a drive, if I stop (get gas, run an errand, etc) when I go to fire her up again it’s hit or miss. Usually I’ll slightly depress the gas peddle and turn it over and it starts, but sometimes it weekly starts and then fizzles out. When this happens, if I attempt to restart it just turns and turns but won’t fire. I don’t like knowing whether it will start again or not when warm, and am sure this isn’t correct. Can any experts out there give me some trouble shooting tips or advice?
Old Sep 1, 2019 | 10:37 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Just a guess, but I'd look at the coil.
Old Sep 1, 2019 | 11:52 PM
ronarndt's Avatar
ronarndt
Since you are having trouble starting after the engine is hot and sits for a while, I would also check for whether there is fuel in the carburetor fuel bowl or whether the engine heat has boiled and evaporated some or most of the gas out while it was sitting there...... so you now have a dry carburetor. Take the air cleaner off, look down into the carb and move the throttle lever and note if gas comes out of the little jets for the accelerator pump. My 68 would boil out almost all of the fuel if the car sat for 15-20 minutes after the engine was hot. I had to crank it for 30-40 seconds before the fuel pump got enough gas back into the carb so it would start. I finally installed an electric fuel pump and now I just turn the key to "on" and let the fuel pump run for about ten seconds before I activate the starter. Now it starts immediately. Not sure if your car has the same problem, but it is something to check. Hope you get it fixed.
Old Sep 2, 2019 | 12:14 AM
BarryB72's Avatar
BarryB72
That was me a few years ago. I would shut it off wait 5 minutes and listen to the fuel bubbles. Very hard to start.
I had Lars go through the carburetor (it was set a tad incorrectly with wrong jets) and (and I think this was a big issue) I got the heater hose away from the fuel line coming up from the pump to the carb. The heater hose was resting on the fuel line.
Now it damn near acts like a normal car.
Old Sep 2, 2019 | 08:11 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
what kind of carb are you running? Do you pump the gas when its warm? you shouldnt have to, it should fire without a pump, if it doesnt try one pump as you may be creating the problem by flooding it. if not carry a can of starter fluid and give it a quick shot down the throat to see if its a boiling/evaporating problem, a flooding problem or a coil issue. Before you give it a squirt look for gas soaking/sitting in the bottom of the intake by looking down the throat with the butterflies open. When you open them check for the pump squirt as mentioned above.
my issues with evaporating were similar and a pheonolic spacer solved most of the heat soak issues.
Old Sep 2, 2019 | 10:10 AM
kodpkd's Avatar
kodpkd
I have the same problem with my spread bore holley 4175. When it's hot I have to do a flooded start,,, peddle to the floor untill it starts. I have a carb shield and thick spacer. I have replaced the needle, seat, float, valve, fuel regulator, ETC no help! It still does it. I am thinking a fuel return line, to get cold fuel into the carb during start would help. Has anybody tried this?
Old Sep 2, 2019 | 03:27 PM
jcnst1's Avatar
jcnst1
Thanks I’ll do that. It’s a Holley carb.
Old Sep 2, 2019 | 11:19 PM
ronarndt's Avatar
ronarndt
kodpkd- I have tried all of the things you mention and the car already had a return fuel line, which helps only when the car is running.. The heat from the engine would boil out the gas if the car sat for about 15 minutes. I have a QFT 750 carb with four glass sight windows, so you can literally see the fuel level go down as it sits there. The electric fuel pump solved the problem so I don't have to grind the starter to get the old mechanical fuel pump to re-fill the carb.
Old Sep 6, 2019 | 08:23 AM
gguillot's Avatar
gguillot
When you have a warm start situation again, remove the air cleaner and watch the top of the carb as you attempt to start the car. If you see fuel spitting out of the bowl vent as you crank on the starter, then you have a dirty carb. Mine sucked up rust particles from the old fuel tank and gave me the same problem.
Old Sep 6, 2019 | 09:41 AM
kodpkd's Avatar
kodpkd
What in the carb is dirty? Mine shoots fuel out of the front bowl vent. I am going to install a 180* thermostat and fuel line insulation today. I think I am getting to much heat, and fuel boiling. Ronarndt,,,, I was also thinking about adding a fuel return line WITH an electric fuel pump. I also have to crank crank crank but I thought it's because of flooding, not fuel bowls being empty. If fuel is shooting out of the front vent,,, the bowl shouldn't be empty. If the thermostat and insulation doesn't work, I'll do an electric fuel pump. Did you remove the original mechanical fuel pump?
Old Sep 6, 2019 | 12:08 PM
ronarndt's Avatar
ronarndt
kodpkd- If you have fuel shooting out of the carb when you have the no-start problem, obviously the carb is not dry, so your problem must be different from what I was experiencing. I removed the old mechanical fuel pump and used a block-off plate to cover the opening in the block. If you install an electric fuel pump, you should also do the return line as you suggested. This will allow the excess fuel pressure to bleed back into the tank. I would also install a pressure gauge and a pressure regulator. The stock needle and seat in your carb can not hold back much more than about 6 psi, so the regulator and gauge will allow you to control the pressure, otherwise the fuel will get past the needle and seat and flood out the carb.
Old Sep 6, 2019 | 12:22 PM
ronarndt's Avatar
ronarndt
One additional thought. My QFT carb has four glass sight windows that allow you to see the fuel level in the fuel bowls and allow you to adjust the float height by just looking at the fuel level and matching it to a line marked on the carb while the engine is running. Not sure if your carb has glass viewing windows or not. Older carbs required measuring the height of the float while the carb was dis-assembled. Most rebuild kits have a cardboard template to use to get the float set at the correct height. If your float level is too high, it will allow gas to spill out into the intake manifold and flood the engine, especially when you shut it off and it sits there. Did you already check the float level?
Old Sep 6, 2019 | 01:02 PM
kodpkd's Avatar
kodpkd
Yep,,, I set my float just a tiny bit low. That didn't help either. UGH! Does anybody know the PSI of our mech fuel pumps????
Old Sep 6, 2019 | 10:20 PM
ronarndt's Avatar
ronarndt
Mine was running 6 psi. That's also what I set my electric pump to. Originally I installed a high pressure/high volume electric pump that ran 14 psi even with my pressure regulator. It completely overpowered the needle and seat and poured raw gas into the intake manifold. I took that pump off and installed a normal performance one that I could adjust down to 6 psi.
Old Sep 7, 2019 | 10:54 AM
kodpkd's Avatar
kodpkd
I should check the mech pump pressure. I can tell it's a new pump. No telling what someone added to the car. I did do a high flow, 180* thermostat, and fuel line insulation. I can tell the engine is running cooler. My last test run, it didn't hot start flood. It's going to be hot again today for another test. It will make my head explode if it is something as simple as a thermostat!
Old Jan 23, 2020 | 11:48 PM
Dan _R's Avatar
Dan _R
I was thinking about a spacer for heat soak on my 81 with e4me q-jet. mr gasket makes a 1 inch part number 3406 phenolic spacer with gaskets and longer bolts. Is 1 inch a good size?
Old Jan 24, 2020 | 12:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
More than enough. Phenolic spacer helped a little but going to put a holley heat shield on.
Todays gas sucks.. I see guys with TB type EFI that have the same issue too, just not quite as bad as they have an electronic fuel pump.
Seen talk about the possible removal of ethanol gas which would be great but who knows if it will happen.
To Trouble with warm restart
Old Jan 24, 2020 | 06:35 AM
Rescue Rogers
just make sure you have the hood clearance before shutting your hood. I run a 1 inch on my quadrajet and its great. But I have an aftermarket L88 hood
Old Jan 24, 2020 | 08:47 AM
mysixtynine's Avatar
mysixtynine
If its a holley you power valve diaphragm maybe cracked and leaking. You wont see it leak down because the vacuum port for the power valve is in the bottom of the throttle plate.. you wont see it leak from the boosters if it is in fact the power valve. The car will also run very fat with the power valve leaking.
This will effectively dump the fuel in the bowl down into the engine when sitting for a few mins like in the time it takes you to get gas and make it a real pain to start... just like its flooded... cause it is.
The ethanol in the fuel today rots the rubber components in our fuel system... fuel pump diaphragms and power valve diaphragms in holleys. I always put 3oz of marvel mystery oil per 10 galls of gas (this was recommended by edlebrock techs for their fuel pump diaphragms).
Most carbs dont like more than 6 psi before the needle is pushed off the seat. Mech pump cars dont like hot fuel lines... causes vapor lock at the suction side of the pump. Depending on your year and setup of your 69 i believe you could have a vented cap or a non vented cap depending on your tank, fuel line, and or fuel return line setup if you have them or if they have been messed with.
Old Jan 24, 2020 | 10:07 AM
kodpkd's Avatar
kodpkd
I have the same issue with my 68 with a holley 4175. Does your fuel line to the carb have a return line from the filter to the tank? I am installing one today. I have checked ALL the carb fixes everyone is talking about and still get flooded,,"vapor lock" hot start. Float, needle and seat, heat shields and spacers, fuel line insulation, new diapham, ETC ETC! Mine even does it when it's 50* out and the front bowl is luke warm. I believe it is because there is expansion and excess pressure in the fuel line. Does your car have a return line?
I have a return style filter I am going to install, GF-432. I'm not sure the new ones are made correctly. The one I got doesn't have any restriction in the 1/4 inch return port. I'm going to put a restrictor in the line from the filter to the tank.
