Hi all
I have made a few enquiries through this forum to get my C3 up together
Its a 1971 coupe
Passenger side headlight refuses to come up, drivers side works ok but is a bit slow, I cannot physically lift the passenger side- it seems locked, looks to me like the vacuum actuator is seized???
I can lift the drivers side no problem but the passenger side refuses to budge I can seem and check all the springs and levers all move a little but the actuator seems stuck
Is there a strip down guide for the actuator??
Cant get the horn to work- checked out the wiring looks like the relay and horn work but the horn button doesn’t operate the relay!!!! Any thoughts please
Thanks to all for continues support keeping these beautiful old cars on the road in the UK
2016 C3 of Year Finalist
YOu can push up on it from underneath. The way the arms are articulated you will have a hard time openning them from above. THeres a hinged lever that moves them up anddown. If yo play with the one that works you ccan find the arm yo need to push on and it will open pretty easily.
As for the problem yo may have a bad actuator , relay or just a substantial leak
Yes, I forgot to mention that. By design you can't lift the doors by simply pulling on the front edge. You can though raise them by reaching under the nose and pulling the linkage towards you. Again though if there's vacuum at the rear of the actuator the door will seem completely seized.
