Should I ????
Old Nov 12, 2002 | 02:56 PM
l2vette's Avatar
l2vette
Default Should I ????
Should I disconnect the heater hoses from the heater core and run a loop? Since the heater and a/c system are not working, do you think this is a good idea or what??
Thanks for any input.
:chevy
Old Nov 12, 2002 | 03:11 PM
Martin72's Avatar
Martin72
Default Re: Should I ???? (l2vette)
You can run a loop....or just block them off...either way it won't hurt the engine and will help keep the inside of the car cooler.
Old Nov 12, 2002 | 03:12 PM
DaddyO's Avatar
DaddyO
Default Re: Should I ???? (Martin72)
If you run a loop, how do you drain the coolant out of the heater core? Is that necessary?
Old Nov 12, 2002 | 03:16 PM
72GACRZR's Avatar
72GACRZR
Default Re: Should I ???? (DaddyO)
It would probably be better to put a shut off valve in the in side and open it once in a while. the two hoses are different sizes, I think. If you leave the core cut off completly it will rust eventually.
[Modified by 72GACRZR, 3:16 PM 11/12/2002]
l2vette's Avatar
l2vette
Keeping the inside of the car cooler is a plus. How much of a difference??
Old Nov 12, 2002 | 03:20 PM
l2vette's Avatar
l2vette
Default Re: Should I ???? (72GACRZR)
Rusting out the core is a concern!! Anyone doing this with thier Vette??
Old Nov 12, 2002 | 03:34 PM
Marks69BB's Avatar
Marks69BB
In my case, the heater core was leaking so I connected the two hoses with a 5/8 to 3/4 hose adapter I bought at NAPA. If your heater core is ok, the cutoff valve sounds like the best way to shoot coolant through there every once in a while to prevent rustout. Only caution is that your heater core could leak inside the car and mess up your carpets. Mine leaked at the hose connection under the car instead of inside.
Old Nov 12, 2002 | 04:10 PM
Fevre's Avatar
Fevre
One draw back to bypassing or eliminating the heater core is that the defrost/defog will not work. Not a major concern 99% of the time but that 1% could mean seeing out you windsheild.
Old Nov 12, 2002 | 07:36 PM
Bullyj's Avatar
Bullyj
I installed ball valves on both hoses that way I can open it up for the winter months and shut it off for the summer, but I do open it every now and again in the summer to keep it from rusting. It made a big diference in the cabin temperature. I got the stuff a Lowe's
Old Nov 12, 2002 | 09:43 PM
cchristo's Avatar
cchristo
I installed a heavy duty shut off valve (ball type) in the line running to the heater core. Get a good, quality one, not a garden hose type. I open mine up regularly during the summer just to keep the core flushed. I haven't had any problems and it does make the cabin a LOT cooler.
chris :cheers:
To Should I ????
