zz502 timing chain slack
while checking several things at my zz502 I came about the timing chain slack.
I can rotate the crank 4° back and forth without rotating the cam.
This ist about 5mm or 1/5" on the balancer.
(measured with a dial gauge on a rocker arm, but the slack is also feelable at the crank)
Should I replace the chain? The engine has only 30k miles of street use.
In my opinion a bit early for chain wear, isn´t it?
I know new chains have nearly zero slack, but they stretch soon after the first miles.
A couple of degrees isn't too bad. Will lose a little low end grunt.
OP, are you taking degree measurements at the pushrod tip with the rocker removed?
Jebby
BUT.....if that is all you are seeing at the rocker arm measured that way......put it back together and run it.
Jebby
Usually people measure the slack with the distributor rotor. But this has some play, 2° in my case, which can give your additional measurement failure. So I decided to measrue directly on the cam. All you need to know is if the cam moves back and forth. Nothing else. The dial gauge shows every little movement, of course I had the the rocker on half of its travel for best indication.
Btw I saw on the dial how the lifter went down very slowly. I had to wait 5 minutes until the lifter was empty and bottomed out.
Then I made a marking on the balancer. Turned the crank for the second marking. Result is 4° movement of the crank.
This is also what I can feel by hand.
Is 4° a usual value for a broke in chain, or should I replace the chain?
Jebby
Such as align-bore. Any time the camshaft line and the crankshaft line come closer together, even a thousandths of an inch will affect your measurement.
If the crank journals were turned 0.010 and the main bearings were not oversized to compensate, then again you have . . . . .
There are special chains that can be ordered undersized to compensate additional slack also.
Unless this is an all-out Prostock engine, I would not worry about 4* unless you have too much time on your hands and are a perfectionist.
So to the poster your stretch was thought into the equation.
With the 0.001 increments you can see the slightliest movement.
Valve spring is stronger than lifter, once it´s fully compressed there´s no more measurement failure.
@gkull, my main issue was slightly jerking at low load, cruising at aroum 30mph, feels like litte missfire. I started a own thread for that issue,
and will continue there. Started this one to get the right attention for this special topic.
Engine runs perfect despite the tiny jerks. I want it perfect, and valve train was the last thing that was not checked. (everything ok there)
Bouncing timing could be a reason for my problem, that´s why I could be concerned about the slack in the chain.
Unfortunately I did not measure it when the engine was new. But who measures all that stuff at a new engine? You think you are fine for at least
100k miles.
I think I will check the slack later and see if it gets worse.
If other zz502 owners could post their values this would be a good comparision.
Jebby
The O.P. is not comparing the manufacturers cam specs with the specs he is finding. No degree wheel is involved. He is comparing when the crank moves and when the cam moves, both in clockwise rotation & counter-clockwise rotation. This test has nothing to do with four degrees built into the cam or zero degrees into the cam.
Its strictly chain stretch comparison.
Also, the four degrees of advance built into the cam, from stories I have read was for customer satisfaction. When a customer spent his or her hard earned money on a cam kit, they wanted instant results. As soon as everything was bolted up, a test drive showed gobs more torque than before = one happy customer. How do you get extra torque? Advance the cam four degrees.
The OP was wondering about chain slop. It's okay
