Blown stop light fuse
Old Sep 25, 2019 | 02:29 PM
Srnes1@aol.com's Avatar
Srnes1@aol.com
Default Blown stop light fuse
As soon as I attempt to replace the brake light fuse it blows ,my turn signal fuse was also blown. I replaced the turn signal fuse but the signals dont work, does it have any correlation to the blown brake light fuse that keeps blowing
Old Sep 25, 2019 | 04:58 PM
MelWff's Avatar
MelWff
Concerning the turn signals, when you say they dont work, do the turn indicator lights on the instrument cluster light up?
If they do and dont blink, have you checked the front and rear for a burnt out bulb?
Concerning the brake lights, have you looked at the condition of the bulb sockets which may be related to the first problem?
Could you also either complete your profile or state what year the car is?
Old Sep 25, 2019 | 07:34 PM
Srnes1@aol.com
It's a 1969 Corvette and no the instrument panel does not light when I turn the signal on. Thanks
Old Sep 26, 2019 | 08:41 PM
righthanddrive's Avatar
righthanddrive
If the fuse blows as soon as you install it, you have a dead short. Possibly the wiring harness got too hot and melted some insulation, or a wire is touching the engine that isn't supposed to. Or some other metal on the frame. The fiberglass bodies do not conduct electricity.
Old Sep 29, 2019 | 04:03 PM
SwampeastMike's Avatar
SwampeastMike
The first things to check are the lamp sockets. They can break and the contacts touch each other producing a dead short.
To Blown stop light fuse
